[OpenFOAM] Parallel visualization wo reconstruction |
November 27, 2007, 04:56 |
Thomas Jung
Rep Power: 17 |
Hi everybody,
Is there any way to do visualization without reconstructing a parallel case? After all, I understand that paraview can be launched as a parallel job, do the visualization in parallel and send somehow the result to a workstation. Maybe converting to vtk format first? Thx for any hint! Thomas |
November 27, 2007, 05:13 |
Hi Thomas,
A (too?) simple w
Rasmus Hemph
Rep Power: 17 |
Hi Thomas,
A (too?) simple way is to run foamToVTK in the processor-directory you are interested in and view just that part in Paraview. I too would be interested to know if anyone is using the full parallel capabilities of Paraview for multi part viewing. |
November 27, 2007, 06:11 |
Actually, the workarounds are
Rep Power: 18 |
Actually, the workarounds are only a temporary solution, which in long run for some cases does not work well. If somebody could provide nice explanation how to use paraview in parallel that would be great. Somehow in cases which I was testing, single processor was not enough, therefore I had to switch to Tecplot.
November 27, 2007, 08:14 |
Ah, just realized watching sim
Rasmus Hemph
Rep Power: 17 |
Ah, just realized watching simulation results of parallel simulation without reconstruction was easier than I thought. No need for foamToVTK, just do a soft link to system in each processor-directory and open in ParaView. (I am using the excellent reader Takuya Oshima realeased about a month ago).
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/5777 (Still nothing parallel about the viewing though!). //Rasmus |
March 19, 2008, 04:56 |
Has anyone experience with usi
Frank Bos
Rep Power: 18 |
Has anyone experience with using ParaView3 in real parallel. So running ParaView3 on a cluster using mpi ???
If so, is it easy to setup? Frank
Frank Bos |
Display Modes | |
Reconstruction of the parallel case with dynamic mesh | makaveli_lcf | OpenFOAM Post-Processing | 7 | October 18, 2023 11:28 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
