Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] View the pressure drop contour in a cut plane 2D in a right position
Old   February 13, 2008, 03:57
Default View the pressure drop contour in a cut plane 2D in a right position
ZHOU Bin
Location: Nanjing/Torino, Nanjing/Piemente, China/Italy
zhoubinwx is on a distinguished road
Send a message via ICQ to zhoubinwx Send a message via MSN to zhoubinwx Send a message via Skype™ to zhoubinwx
Hello, now I want to view my pressure drop contour after I make a cut plane, but when I rotate it using left mouse, then it is difficult for me to view it in the first position ( for example, from the normal direction of this cut plane).
Thank you.
zhoubinwx is offline   Reply With Quote
Old   February 13, 2008, 04:07
Default Hi zhoubin, In the View menu,
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi zhoubin,
In the View menu, there is an item called 3D View Properties which contains a tab called Camera. There you can set the view as you like.
dmoroian is offline   Reply With Quote
Old   February 13, 2008, 04:14
Default And you are aware of the butto
Assistant Moderator
Bernhard Gschaider
And you are aware of the buttons on the top right that help you to set the center of rotation?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 13, 2008, 04:46
Default Hi, dear Dragos Moroianu and B
ZHOU Bin
Hi, dear Dragos Moroianu and Bernhard Gschaider, I have practiced the Camera, and it works very well, so thank you, Dragos Moroianu. And the way to set rotation center surprised me a lot, so thank you, Bernhard Gschaider.
Well, I am a student in Politecnico di Torino, if you need any help, I am glad to do contribution.
Best regards,
Zhou Bin
(zhoubinwx@hotmail.com)
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
Define pressure drop across a plane raymond350 FLUENT 1 May 7, 2012 02:31
Unable to view contour plot on a plane azurespirit ANSYS 0 May 23, 2011 08:35
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
CFX4.2 Pressure contour kink Stuart McCallum CFX 3 July 7, 2000 14:09
