[OpenFOAM] Is it possible to use ParaView 321 with OF 141 |
December 28, 2007, 07:13 |
Pietro Asinari
Rep Power: 17 |
I have some problems in using ParaView 2.4.4 with my system (Ubuntu 7.10) essentially because of Beryl. The GUI shows some strange transparency in the buttons. The problem has been already fixed by ParaView 3.2.1. Is it possible to use ParaView 3.2.1 with OF 1.4.1. I tried by substituting the files in the folder paraview-2.4.4, but it is not working. Any suggestions ? Thanks, Pietro |
December 28, 2007, 09:43 |
You can use the foamToVTK conv
Mattijs Janssens
Rep Power: 26 |
You can use the foamToVTK converter.
You'll have to adapt your $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/paraview/bashrc (sourced from your ~/.OpenFOAM-1.4.1/bashrc) to pick up the correct paraview executable. |
December 31, 2007, 05:00 |
Hi Mattijs,
thank you for t
Pietro Asinari
Rep Power: 17 |
Hi Mattijs,
thank you for the suggestions. I will try them. Best, Pietro |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 05:48 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 13:24 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
[OpenFOAM] Problems using paraview 244 under open FOAM 141 or 13 | sergio | ParaView | 0 | March 13, 2008 13:52 |
