[OpenFOAM] Is it possible to use ParaView 321 with OF 141
Old   December 28, 2007, 07:13
Default Is it possible to use ParaView 321 with OF 141
Pietro Asinari
pasinari is on a distinguished road
I have some problems in using ParaView 2.4.4 with my system (Ubuntu 7.10) essentially because of Beryl. The GUI shows some strange transparency in the buttons. The problem has been already fixed by ParaView 3.2.1.
Is it possible to use ParaView 3.2.1 with OF 1.4.1. I tried by substituting the files in the folder paraview-2.4.4, but it is not working. Any suggestions ?
Thanks,
Pietro
pasinari is offline   Reply With Quote
Old   December 28, 2007, 09:43
Default You can use the foamToVTK conv
Mattijs Janssens
You can use the foamToVTK converter.
You'll have to adapt your $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/paraview/bashrc (sourced from your ~/.OpenFOAM-1.4.1/bashrc) to pick up the correct paraview executable.
Old   December 31, 2007, 05:00
Default Hi Mattijs, thank you for t
Pietro Asinari
Hi Mattijs,
thank you for the suggestions. I will try them.
Best,
Pietro
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
[OpenFOAM] Problems using paraview 244 under open FOAM 141 or 13 sergio ParaView 0 March 13, 2008 13:52
