December 21, 2007, 06:09 |
Newer
weihong yao
Rep Power: 17 |
when I follow the "tutorials",there is some errors.i don't understand how to type
paraFoam <root> <case> if user name is ivan and the case name is "cavity".how to type it in order to show the Paraview? |
December 21, 2007, 11:39 |
I once again request you to re
Rep Power: 18 |
I once again request you to read the user guide. Its all in there. Forum users assume that you have read the user manual.
Anyways I try to answer your question: OpenFOAM commands have a general format: command <root> <case> where <root> is your root directory where <case> is the directory where you case lives before executing a command make sure that you know what is your <root> and <case> now with your username your shell prompt should be something like: ivan@hostname:~> cd to the directory where your case lives so that when you do ll it should list you case directory Then try ivan@hostname:~> paraFoam . cavity In the above example your <root> is the current directory "." and cavity is your <case> directory. For more info check out some Linux forum. Hope that helps Jaswinder |
December 22, 2007, 00:05 |
thanks
weihong yao
Rep Power: 17 |
thanks
December 22, 2007, 00:08 |
thanks i try it.
weihong yao
Rep Power: 17 |
thanks i try it.
pyFoamTimelinePlot with newer Openfoam versions | arieljeds | OpenFOAM Post-Processing | 0 | June 6, 2016 09:46 |
Ansys older version to newer? Ansys 13 to lower version? | paka | ANSYS | 2 | November 28, 2013 12:29 |
(x-post from 'bugs') mesquite-2.1.2 compile fix for newer gcc | kmooney | OpenFOAM Installation | 1 | May 9, 2012 17:32 |
newer version of Fluent/ CFX Vs. CFX11?!? | mohammad | CFX | 3 | May 26, 2011 09:38 |
patchTool, is there a newer alternative? | bigphil | OpenFOAM Pre-Processing | 4 | October 19, 2009 07:56 |
