August 13, 2007, 07:58 |
Animation
Christian Lindbäck
Rep Power: 17 |
I would like to receive advices on the best way to create animations in paraFoam. I'm using Linux OpenSUSE 10 and it is required that the animation works fine on Windows XP.
1) Should I create an animation directly in paraFoam or print images and use some Linux software to assemble them into an animation? In the latter case, what software do you recommend? 2) What settings in paraFoam do you recommend me to use / not to use when creating the images/animation? Are there any known pitfalls? Best regards, Christian Svensson |
August 13, 2007, 08:29 |
pitfalls:
if you have big p
Thomas Jung
Rep Power: 17 |
pitfalls:
if you have big problems, uncheck the "cache mesh" button, and the "cache geometry" button in the animation control view, otherwise you easily run out of memory. For me it works now simply to save the animation as mpg from paraFoam. However, using XP, I did not find a way to specify a framerate in presentations. Thats why I now save jpg's, then use convert from ImageMagick to convert to yuv, and then mpeg2encode to prduce an mpeg with a framerate as I want it. Oh, one more hint: I am also using OpenSuse, and had problems that, when creating animations, I could not put any window in front of paraFoam, it would appear in the animation. However, this does not happen if I just start, kill paraFoam, nd re-run paraview using the trace file as input. regards, Thomas |
October 1, 2007, 16:50 |
I have unsteady Lagrangian par
Sung-Eun Kim
Rep Power: 17 |
I have unsteady Lagrangian particle data I want to make animation of - bubbles wandering about in an unsteady flow field. The procedure I use to vsualize the particles
- convert Foam to VTK format (foamToVTK) - Use paraview to open the flow data and the particle data - glyph the particle data to visualize the bubbles I can generate as many snapshots as I want in this way. My question is how I can make animation out these snapshots. HWat procedure should I use to make animation |
October 3, 2007, 15:40 |
Use ImageMagick or mencoder (f
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Use ImageMagick or mencoder (from mplayer):
For example, try: mencoder "mf://*.png" -mf type=png:fps=1 -vf spp,scale -ovc lavc -o output.avi Assuming you have images in png format. |
Solution Animation Error | Jacob_Bing | FLUENT | 2 | July 28, 2022 08:10 |
Creating animation through TUI | wawa | FLUENT | 27 | November 5, 2021 03:17 |
Animation Sweep Plane not displaying correctly | u2berggeist | FLUENT | 1 | August 26, 2018 20:51 |
Multiblock animation in Tecplot. | Simon | Tecplot | 4 | February 10, 2006 10:27 |
Animation query..newbie qn | derick | FLUENT | 2 | December 9, 2005 09:45 |
