[OpenFOAM] Multiple independant data sets in paraFoam |
August 27, 2007, 10:47 |
Christian Lindbäck
Rep Power: 17 |
I would like to place tree contour cuts through my domain next to each other. The top one, middle one and bottom one are supposed to show contour plots at different times.
When I create cuts, I can't move them individually why they all lie on top of each other. I want to treat them individually. I've tried to copy my data to a directory with a different name and them opened the cases in different names. This didn't work. The two data sets are treated as coupled and end up lying on top of each other. So, how can I open data sets and treat them indiviually? Best regards, Christian Svensson |
August 27, 2007, 13:30 |
Hi Christian!
I don't know
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Christian!
I don't know if I understood your question correctly (the part of copied data not working threw me a bit off the track): Vizualizing different timesteps of the same datastep is possible 1. open the data set with "paraFoam . damBreak" 2. Vizualize first timestep 3. Go to the "File-Open Data"-Dialog. In the damBreak-directory should be a file damBreak.foam. When you open that you get a new Source with an indepentent time 4. Now you can vizualize that Of course the data-sets will be spatially aligned, but you can change that, either by applying the Transform-filter or the "Actor Control" in the Display pane (this works only for the current actor not for stuff later in the pipeline) Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Display Modes | |
Scheme programming-read multiple data files from transient computations | anuarun | Fluent UDF and Scheme Programming | 3 | March 5, 2021 21:27 |
Mapping and apply operations on multiple data sets | ginop | OpenFOAM Post-Processing | 0 | December 20, 2018 04:10 |
saving Transient/Unsteady data of multiple surface integrals in single file | ankur gupta | FLUENT | 0 | February 22, 2012 14:59 |
ParaFoam : Written data doesnt have Full Regions | Velan | Main CFD Forum | 0 | January 12, 2009 04:55 |
Need sample data sets for testing | Arthur Gehring | Main CFD Forum | 0 | September 13, 2002 14:28 |
