Home > Forums > OpenFOAM Paraview & paraFoam
Annotating parafoam with timestep info
Old   September 19, 2005, 01:37
Default Anybody know whether it's poss
Ron W Cresswell
roncresswell is on a distinguished road
Anybody know whether it's possible to annotate a keyframe animation in paraview so that the solution time is on the image and updates as the animation proceeds?
Thanks in advance,
Ron
roncresswell is offline   Reply With Quote
Old   April 21, 2006, 09:46
Default This has been recently discuss
theof
This has been recently discussed into the paraview mailing list, look at the thread Live Annotation
http://public.kitware.com/pipermail/...ead.html#start
Thinking about adding it to the PVFoamReader...
Th
Old   May 18, 2007, 19:09
Default I have similar problem. Basica
rafal zietara
rafal is on a distinguished road
I have similar problem. Basically I just want
to show time (in seconds) in the image. I have
found similar solution on Kitware website,
but it displays frame number and not real time.
the solution was to write this thing (below)
in annotate:
Time: [[[[$Application GetMainWindow] GetAnimationManager] GetAnimationScene] GetAnimationTime]
Is there an easier way to get required time?
Do I really need to write this kind of spells?
and more important what spell to cast in order
to get time in seconds?
I appreciate any help (or where to look for help).
Thanks in advance.
rafal
rafal is offline   Reply With Quote
Old   May 19, 2007, 09:37
Default hey i dunno know how it's d
Markus Hartinger
hartinger is on a distinguished road
hey
i dunno know how it's done in paraview, but you could use 'convert' to add it afterwards with a little script
'convert' you get from:
http://www.imagemagick.org/
hartinger is offline   Reply With Quote
Old   May 19, 2007, 09:56
Default Thank you Markus for your repl
rafal zietara
Thank you Markus for your replay. It seams
that i will need to come back to old good
imagemagick and convert .
First take pictures from paraview as .jpg.
Than by convert add text (from names of files)
to .jpg files.
and at the end use once again convert to
make a movie.
But the problem is that the last convert
to make a movie uses lots of resources
(temp storage, and takes ages)
Is there a simpler way of doing it from paraview
only?? It should be a trivial thing to include
time on a slide. isnt it?
anyone any idea?
Old   May 19, 2007, 10:07
Default I forgot to mention that i fig
rafal zietara
I forgot to mention that i figured out how to obtain
this effect if we have constant time step. We can
take use of tcl/tk and correct previous command to:
Time: [expr [[[[$Application GetMainWindow] GetAnimationManager] GetAnimationScene] GetAnimationTime]*0.5] s
where 0.5 would be a timeStep. but my time step is not constant so i am still in the same place.
waiting for other suggestions. or maybe... is there a way to get time step in paraview?
or maybe other solution? anyone?
Old   May 21, 2007, 13:10
Default Tecplot if you have the licens
liu
Xiaofeng Liu
liu is on a distinguished road
Tecplot if you have the license.
Xiaofeng Liu, Assistant Professor
Department of Civil and Environmental Engineering
University of Texas at San Antonio
email: xiaofeng.liu@utsa.edu
Web: http://engineering.utsa.edu/~xiaofengliu
liu is offline   Reply With Quote
Old   May 22, 2007, 03:43
Default Hi Rafal, Maybe you should co
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Rafal,
Maybe you should consider OpenDX. OpenFOAM has an excellent writer for it (dxFoam).
It is at least feature rich as paraview, if not more, and definitely it is very easy to add any kind of text to each frame, like the name of the current time directory.
Dragos
dmoroian is offline   Reply With Quote
Old   May 28, 2007, 08:14
Default Xiaofeng, yes if i only have a
rafal zietara
Xiaofeng, yes if i only have a license
Dragos, I spoke with you about OpenDx during SIMDI'06 in Goetheborg. I know you are a big fan of it. I tried some examples than, like you advised me. It seemed to me that i need to learn a lot of things about it to use it. Now I think it is worth to spend 2-3 weeks to learn it and not have such a simple and difficult problems with paraview.
I didnt find solution in paraView. For the recent presentation i had, I just recalculated everything with constant timestep and used annotation method described above. Dummy's solution. I will move to OpenDx once I have some free time to learn it more. Thanks Dragos.
rafal
Old   May 29, 2007, 03:36
Default Hi Rafal, I'm impressed that
dmoroian's Avatar
Dragos
Hi Rafal,
I'm impressed that you remembered me. Regarding OpenDX and its easiness of usage, I can make a parallel to OpenFOAM. Wasn't very hard to learn it in the beginning, and maybe it is still? But how great is it now, when you think of its potential?
I hope we can meet again at future OpenFOAM workshops.
Dragos
Thread Tools
Trackbacks are On
EFD Info Tom FloEFD, FloWorks & FloTHERM 2 January 12, 2009 13:11
some info please andrea Main CFD Forum 2 October 9, 2008 17:10
Info about CFX Dip CFX 2 May 3, 2007 14:33
Where to get these info.. Jas Phoenics 2 January 15, 2004 06:02
info olivier Main CFD Forum 0 November 16, 2001 12:08
