Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Foam Fatal Errorunknown function type probes
Old   May 15, 2007, 09:51
Default Foam Fatal Errorunknown function type probes
mayank
I have successfully installed openfoam. FoamX works fine.the calculations for icofoam, simplefoam tutorials are also fine.
But when viewing the mesh in paraview for icofoam Cavity, it gives the following error:
FOAM FATAL ERROR : Unknown function type probes
Table of functionObjects is empty
From function functionObject::New(const word& functionType, const Time&, const dictionary&)
in file db/functionObject/functionObject.C at line 70.
FOAM exiting.
Also when viewing simplefoam Pitzdaily ,paraview window opens,but no mesh is visible even after clicking the Accept button.
I need some urgent help.
TIA
Old   May 15, 2007, 09:56
Default Comment out the "functions" se
Eugene de Villiers
eugene is on a distinguished road
Comment out the "functions" section in your controlDict. functionObjects are not compatible with paraFoam at present.
eugene is offline   Reply With Quote
Old   May 15, 2007, 10:13
Default this helped but i still do not
mayank
this helped but i still do not see any mesh for icofoam and simplefoam. I can just view a blank paraview screen even after clicing Accept button.
Thanks.
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 19:50
multiphaseEulerFoam/tank discharge ves OpenFOAM Running, Solving & CFD 8 December 31, 2017 14:59
rhoPimpleFoam hardship petrus OpenFOAM Running, Solving & CFD 0 October 7, 2016 02:41
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
