Home > Forums > OpenFOAM Paraview & paraFoam
ParaFoam OF 14 decomposed cases
Old   April 16, 2007, 14:12
Default Hello, I was testing out Op
Philippose Rajan
philippose will become famous soon enough
I was testing out OpenFOAM ver.1.4 a few days ago, and found that when I try to visualise a decomposed mesh with paraFoam, it throws up an error saying that the controlDict file could not be found.
In the earlier versions of OpenFOAM, I could go into the case folder of a decomposed case, and use (for example):
paraFoam . processor0
or
paraFoam . processor1
and it would open ParaView and display that part of the mesh which belongs to the particular processor.
In the paraFoam file of version 1.4, the script looks for a valid "controlDict" or "fvSolution" or "fvSchemes" file before moving ahead... since the "processor<x>" folder has no "system" folder within, paraFoam exits with an error.
Was this modification made with the idea of introducing (in the near future) the capability of being able to visualise decomposed cases in ParaView without first having to reconstruct them, or was it just an oversight?
Currently I use the ParaFoam script from one of the earlier versions, and things work fine....
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   April 17, 2007, 02:45
Default > or was it just an oversight
Mattijs Janssens
mattijs is on a distinguished road
It was just an oversight. Remove the check or use the old script.
mattijs is offline   Reply With Quote
Old   April 17, 2007, 04:18
Default Attached is a version that doe
Mark Olesen
olesen will become famous soon enough
Attached is a version that does the correct checking paraFoam for serial and decomposed cases.
BTW: you can simply issue 'paraFoam' to view the results in the current working directory or 'paraFoam DIR' to specify a particular directory (see 'paraFoam -h')
olesen is offline   Reply With Quote
Old   April 17, 2007, 13:25
Default Hi Mark, Thanks a lot for t
Philippose Rajan
Hi Mark,
Thanks a lot for the modified paraFoam script :-)! Works like a charm!
Now all that is remaining, is for someone to take the time out to modify the vtkFoam reader to enable a decomposed mesh to be visualised (in its entirety) without having to reconstruct it.
Have a nice day!
Philippose
Old   April 18, 2007, 05:17
Default Hi Philippose, From what I'
Mark Olesen
Hi Philippose,
From what I've gathered, paraview 3 might make it easier to write a parallelized reader.
Thread Tools
Trackbacks are On
Reconstruction of decomposed dynamic mesh cases david OpenFOAM Post-Processing 2 January 9, 2009 08:19
ParaFOAM ttdtud OpenFOAM Paraview & paraFoam 2 May 29, 2008 09:08
How to iterate over all cells in decomposed mesh tehache OpenFOAM Running, Solving & CFD 4 October 23, 2007 10:06
Reading 3d cases with paraFoam sriharsha OpenFOAM Paraview & paraFoam 5 January 23, 2007 15:52
Please help me see this about paraFoam liugx212 OpenFOAM Running, Solving & CFD 2 March 8, 2006 10:54
