Paraview problem
Hi there:
I am an OpenFOAM starter. I have a question with paraview: when I tried to open paraview using parFoam to view mesh, paraview ooped up and GUI looked fine except I couldn't see mesh window. Anybody knows why this happens? Ning |
Press the big button "Accept"
Press the big button "Accept" in paraview http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
Dragos |
I already did. No response.
Ning |
Do you have a time directory?
Your case directory should look like this: case_dir/0 case_dir/constant case_dir/system Anyway, if you follow the first tutorial in the "User's Guide", it should work, and that will give you a hint on what are you doing wrong now. Dragos |
one possible thing is "/" at t
one possible thing is "/" at the end of
paraFoam <root> <case>/ which is added when you press TAB instead of typing a full case name. other: how did you installed your paraFoam? if you compiled on your own than you can have problems like this if you didnt do it correctly (i did have when i compiled first two times - solution: Follow the guide on wiki). do you have any messages in your shell (usually OF provides usefull hints in shell)? hope that helped good luck and happy easter rafal |
On my local PC I am using Xter
On my local PC I am using Xterm (exceed) to connet to the linux server on which the openFOAM is installed. But when I type the conmand "paraview", the paraview windown does not open up, and the error message says "Xlib: Extension "GLX" missing on display "192.168.0.170:0.0".
Please help. Thanks |
OK, I am not the exact "proble
OK, I am not the exact "problem solver", but couple tips.
BTW. What linux distribution are you using? First of all, the problem requires administration privalages. 1 tip: Go to you admin and just ask about it. He, as an UNIX guru, should know what is wrong. Just tell him and explain you use VTK (Visualization Toolkit), and you just NEED it http://www.cfd-online.com/OpenFOAM_D...part/happy.gif 2 tip: I assume you got these administrative privalages. The reason why it doesn't work is the GLX (OpenGL Extension to the X Window System). So in order to make it run do followings: 1. Be sure you have the newest graphics drivers. nVidia? ATI? Whatever you use. Exception could be a built-in Intel card, then use 955resolution drivers. Just type XGL or GLX Intel graphic card driver in Google, this should help for some solutions. 2. step. Write in xterm: sudo gedit /etc/X11/xorg.conf Add in "Module" section Load "glx" These steps probably COULD help, but DON'T have to. In my case the whole modification process was "a bit" more complicated and took much more time. To check if GLX is enabled type in your terminal window: glxgears if this doesn't work it means GLX is not working. When they appear you can be sure GLX is fine(!). Hope that helped a little bit, and forgive me my very brief descriptions. It is really hard to say what you should do, because Linux is always different case depending on the used machine. PS. Try to use Google for XGL/AIXGL or GLX enableing. It will take you some time, but sure finally (if you are lucky enough) it will work. PS2. Sorry for sending you out to Google, but it really works and helps me a lot http://www.cfd-online.com/OpenFOAM_D...part/happy.gif PS3. The best solution is go to your linux distro internet forum and ask for help over there. They are the best guys to ask for help. Good luck! Krystian |
Dean Wang
In order to launc
Dean Wang
In order to launch Paraview from a remote machine, you'll need to forward X from the remote server to your local computer. If you are using ssh, you can do so by: ssh user@server -X Best regards, José Santos |
