Home > Forums > OpenFOAM Paraview & paraFoam
Reading 3d cases with paraFoam
Old   December 28, 2006, 10:08
Default Hi, I am new to OpenFoam an
sriharsha kandala
sriharsha is on a distinguished road
I am new to OpenFoam and am trying to use paraFoam for post processing. It works well with 2-d cases. However when i try to read 3d cases the application crashes. Can someone help me with this issue. I am enclosing the error message below:
Thankyou
*************error message************************
--> FOAM FATAL ERROR : Not implemented
From function void CyclicPointPatchField<patchfield,>::evaluate()
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/CyclicPointPatchFie ld.C at line 187.
FOAM aborting
/home/kandsri/OpenFOAM/linuxAMD64/paraview-2.4.2/lib/paraview-2.4/paraview-real: symbol lookup error: /home/kandsri/OpenFOAM/OpenFOAM-1.3/lib/linuxAMD64Gcc4DPOpt/libOpenFOAM.so: undefined symbol: cplus_demangle
sriharsha is offline   Reply With Quote
Old   January 1, 2007, 08:03
Default This has been discussed before
Mattijs Janssens
mattijs is on a distinguished road
This has been discussed before. Have a search for
CyclicPointPatchField.
mattijs is offline   Reply With Quote
Old   January 1, 2007, 13:58
Default Hi, I have read the disc
sriharsha kandala
I have read the discussion for CyclicPointPatchField and i have commented the line
in the file CyclicPointPatchField.C and recompiled the library but now i have the issue with demangle.h. I have the library libiberty.a in "OpenFOAM/linuxAMD64/gcc-4.1.0/lib/libiberty.a" but i do not know how to proceed from here. Can you give me some instructions.
Thank you
Old   January 2, 2007, 16:21
Default Install the library on your sy
Mattijs Janssens
Install the library on your system that contains demangle.h (libiberty?). Or get one from the gcc-4.1.0 source tree.
Old   January 4, 2007, 11:53
Default Thanks Mattijs,
sriharsha kandala
Thanks Mattijs,
This resolved the problem.
Old   January 23, 2007, 14:52
Default You could also try out the new
Terry Jordan
tj22 is on a distinguished road
You could also try out the new native paraview reader in the ParaView 2.6 CVS.
tj22 is offline   Reply With Quote
Thread Tools
Trackbacks are On
ParaFOAM ttdtud OpenFOAM Paraview & paraFoam 2 May 29, 2008 09:08
ParaFoam OF 14 decomposed cases philippose OpenFOAM Paraview & paraFoam 4 April 18, 2007 05:17
ParaFoam Ales Alajbegovic (Alajbegovic) OpenFOAM Installation 13 November 7, 2006 09:44
Please help me see this about paraFoam liugx212 OpenFOAM Running, Solving & CFD 2 March 8, 2006 09:54
Problems reading a case cavity into paraFoam red hat 9 anton322322 OpenFOAM Pre-Processing 0 April 11, 2005 13:13
