Home > Forums > OpenFOAM Paraview & paraFoam
Running paraFOam
Old   March 22, 2006, 01:01
Default HI I am just starting to lear
shuo
HI
I am just starting to learn OpenFoam and have been going through the tuts from the user guide. When I try to view the mesh for the case cavity (2.1.2 of the User Guide) I get a window which looks very different from Figure 7.1. The current window has 3 tabs labelled: General, annotate and camera instead of parameters, display and information. I had problems running paraFoam earlier (ie segmentation fault, line 57 in paraview) so I commented that entire file and finally got it to open. It's just that the windows doesn't look the way it should.
SHuo
Old   March 23, 2006, 05:11
Default Your paraFoam installation is
Mattijs Janssens
mattijs is on a distinguished road
Your paraFoam installation is not correct. Fix it or use
- foamToVTK to convert results to vtk format
- paraview and load in the .vtk files
mattijs is offline   Reply With Quote
Old   March 26, 2006, 19:16
Default I tried running it again and i
shuo
I tried running it again and it seems that the error is because the file cavity.foam is empty. Any advice?
Old   September 13, 2006, 23:42
Default That troubles me too. Have you
Wei Zhang
joey is on a distinguished road
That troubles me too. Have you solve the problem? How? Thanks a lot!
Joey
joey is offline   Reply With Quote
Old   September 14, 2006, 07:31
Default Hi Joey! You're refering to t
Assistant Moderator
Bernhard Gschaider
Hi Joey!
You're refering to the post from the 267th of March, are you? As far as I understand it the cavity.foam file is supposed to be empty. It only tells the paraview importer "In this directory you'll find OpenFOAM-data"
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 23, 2006, 09:27
Default Hej, I am just starting to
mss
Hej,
I am just starting to learn OpenFoam and have been going through the tutorials from the user guide. I have some problem with paraFoam..I am trying to run it , but I get a message:
home/margst/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: case directory /home/margst/OpenFOAM/margst-1.3/run/cavity does not
exist, exiting
I typed:
paraFoam $HOME/OpenFOAM/margst-1.3/run cavity
Could u help me, please?
Old   October 23, 2006, 09:40
Default Hej, I solved one problem, bu
mss
Hej,
I solved one problem, but now I have got another one:
/home/margst/OpenFOAM/OpenFOAM-1.3/bin/paraFoam: line 57: paraview: command not found
Anyone know what I should do?
/Rita
Old   October 23, 2006, 09:51
Default Why cannot you find paraview?
Hrvoje Jasak
Why cannot you find paraview? Did you install it? What happens if you say:
which paraview
Are you sure it is on the system?
Hrv
Hrvoje Jasak
Old   October 23, 2006, 10:02
Default Hej Hrvoje, After I typed:
mss
Hej Hrvoje,
After I typed: which paraview , nothing happens.
Should I install paraview separately? It's seems the paraview is not installed. do u know how to install it?
thank you,
Rita
Old   October 24, 2006, 05:38
Default Hi Margarita, Have you rea
Makoto Ueno
ueno is on a distinguished road
Hi Margarita,
Have you read README in OpenFOAM-1.3?
It seems that you have not set the environment variables.
Before running paraview, you should type following command (if you're using bash) to set environment variables.
. $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
Anyway, I recommend you to read the README file before doing that.
Makoto
ueno is offline   Reply With Quote
Old   October 24, 2006, 08:48
Default It seems that you did not inst
  #11
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
It seems that you did not install the third party software:
gcc, paraview and jdk
Did you follow the steps I wrote for you?
If you did, then you have to find in OpenFOAM/linuxAMD64 the following:
home/dragosm> ls OpenFOAM/linuxAMD64/
gcc-4.1.0 j2sdk1.4.2_05 paraview-2.4.2
There you have a directory called paraview-2.4.2 which contains all the binaries for paraview.
Dragos
dmoroian is offline   Reply With Quote
Old   October 26, 2006, 14:43
Default Thank you all, I finaly instal
  #12
mss
Thank you all, I finaly installed all part of OpenFOAM.
/Rita
Thread Tools
Trackbacks are On
Running in patch when your license is running out Andrew CFX 2 August 9, 2007 13:48
ParaFoam nzy102 OpenFOAM Paraview & paraFoam 0 April 13, 2007 20:15
Running paraFoam on remote machine makh OpenFOAM Running, Solving & CFD 3 December 4, 2006 05:12
Problem running paraFoam paraview command not found spdracer22 OpenFOAM Pre-Processing 2 December 7, 2005 06:32
Running paraFoam on remote machine makh OpenFOAM Paraview & paraFoam 1 August 12, 2005 14:42
