September 29, 2006, 01:06 |
Mesh
Hi
is there a way of displaying the boundary patches of the meshed geometry in Paraview so that you know which physical boundaries you are modifying? Shuo |
September 29, 2006, 02:46 |
A similar topic was posted jus
Dragos
Rep Power: 20 |
A similar topic was posted just few days ago:
Displaying solid boundaries It says: use Filters->ExtractParts |
September 29, 2006, 02:52 |
- "Extract Parts" in the "Filt
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- "Extract Parts" in the "Filter"-menu is what you're thinking of.
- Or you're using the "region"-Subpane of the "Parameters"-tab of the data - Propably there is at least a third way to do it in paraview that I don't know about
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
September 29, 2006, 21:14 |
Mesh
Hi
Thanks for the response. What I meant to say is there a way of displaying the names of the boundary conditions on the mesh like in Fluent. With a complex mesh it is hard to know exactly where the boundary conditions are being applied Regards SHuo |
October 2, 2006, 04:59 |
I don't know of any way to do
Mattijs Janssens
Rep Power: 26 |
I don't know of any way to do this. I agree it would be a very useful feature to have though. Anyone with Paraview/VTK knowledge?
October 2, 2006, 09:54 |
This is extremely basic but it
This is extremely basic but it can be done by hand for rather simple geometries using a 3D text source, and playing with the display option. As an alternative you can still write the name of your boundary in the Selection Window. Highlight your surface, then you can change the "Label". HTH
ThF |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
