-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   ParaView command not found (http://www.cfd-online.com/Forums/openfoam-paraview/61246-paraview-command-not-found.html)
joey September 13, 2006 22:14
Hi, everyone I am newbie here
Hi, everyone
I am newbie here, and I just have installed OpenFOAM on my computer.
when I run the cavity tutorial:
paraFoam $FOAM_RUN/tutorials/icoFoam cavity
I got the error message as below:
/usr/local/lib.../bin/paraFoam line 57: praview: command not found
Can anyone help me ?
Thanks a lot!
Joey
mattijs September 14, 2006 04:07
You need to install the paravi
You need to install the paraview pack (downloadable from OpenFOAM as well). See the installation instructions.
(I hope that command not found was 'paraview' and not 'praview')
joey September 15, 2006 00:04
I think the "command not found
I think the "command not found" comes from the shell and I add a line to $HOME/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/apps/paraview/bashrc as below:
export PATH=$HOME/OpenFOAM/linux/paraview-2.4.3/lib/paraview-2.4/bin:$PATH.
The problem solved. Thanks a lot.
tunkers August 28, 2010 21:37
I also had the same problem with openfoam 1.7 when installing on Debian Lenny
paraview would run fine when launched manually, but not from paraFoam.
created temporary 'cavity.OpenFOAM'
/home/cfduser/OpenFOAM/OpenFOAM-1.7/bin/paraFoam: 132: paraview: not found
to fix this, edit the following file
/home/cfduser/OpenFOAM/OpenFOAM-1.7.0/etc/bashrc
add this line near somewhere near the top
export PATH=$PATH:/home/cfduser/OpenFOAM/ParaView-3.8.0-Linux-i686/bin
then
$cd
$. .bashrc
Now you will be able to type paraview from anywhere and it will run. Also paraFoam will also be able to launch paraview.
