Home > Forums > OpenFOAM Paraview & paraFoam
Missing library libPVFoamReaderso
Old   March 7, 2006, 05:40
Default Hello all! After downloadin
dirk_kehrwald
Hello all!
After downloading the sources of OpenFOAM 1.2 together with gcc 4.0.1, j2dsk 1.4.2_05 and paraview-2.2.0 for 32 bit Linux, I could successfully buildt the OpenFOAM package on my Suse 9.0 system. Performing the lid-driven cavity tutorial (Section 2.1 of the User's guide), I was able to follow the instructions until Section 2.1.1.6 (Saving data to file).
Calling now paraview as described in Section 2.1.2., I get the following error message:
ErrorMessage
# Error or warning: ERROR: In ../../../../../paraview-2.2.0/Utilities/VTKClientServer/vtkClientServerInterpret er.cxx, line 866
vtkClientServerInterpreter (0x8064070): Cannot find module "libPVFoamReader.so". The following paths were searched:
<a_lot_of_search_paths>
ERROR: In ../../../../../paraview-2.2.0/GUI/Client/vtkPVXMLPackageParser.cxx, line 677
vtkPVXMLPackageParser (0x87e1b48): Error loading Library component PVFoamReader
ErrorMessage end
<long_path>/paraFoam: line 57: 26343 Segmentation fault paraview paraFoam.pvs
Searching my disc with find, I found that neither libPVFoamReader.so nor any of the source files mentioned in the error message are there. How can I get the missing files?
Kind regards
Dirk Kehrwald
Old   March 7, 2006, 05:54
Default The problem is that you cannot
Hrvoje Jasak
The problem is that you cannot build the paraview reader module without building paravie wyourself locall on your machine. I have posted detailed instructions on how to do this somewhere around - have a look and let me know if you cannot find them.
As a check, go to
OpenFOAM-1.2/applications/utilities/postProcessing/graphics/PVFoamReader
try
./Allwmake
and have a look at the messages - this is the bit that did not get built properly and you'll get paraview-related messages.
Enjoy,
Hrv
Hrvoje Jasak
Old   July 18, 2006, 06:21
Default hi...I have the same problem a
Sreekanth Kolan
sreekanth is on a distinguished road
hi...I have the same problem and i searched for your post and couldnot find. So, can you please post the message in detail how to do the above one because i tried re-building and ended up with same problem again.
please don't mind
sreekanth is offline   Reply With Quote
Old   July 19, 2006, 06:50
Default Dear Sreekanth Kolan, unfor
dirk_kehrwald
unfortunately, I did not solve the problem. I kept trying for a few more days, then I had do do some more urgent work and I did not return to openFOAM since then.
Kind regards
Dirk
Thread Tools
Trackbacks are On
Libsslso098 library missing ahorvat OpenFOAM Bugs 8 October 23, 2009 07:05
LES --> AM I MISSING SOMETHING!? Forrest FLUENT 1 March 4, 2009 18:22
ParaFoam error missing libPVFoamReaderso agrahn OpenFOAM Bugs 3 June 23, 2008 12:34
Missing file nfoxley OpenFOAM Pre-Processing 2 March 31, 2006 08:57
HELP!!! LES missing in fluent 6 ravi FLUENT 2 March 5, 2003 19:27
