Home > Forums > OpenFOAM Paraview & paraFoam
Problems with ParaView
Old   February 24, 2006, 10:37
Default Hi all! Im trying to run par
Alejandro Arrieta
alejo is on a distinguished road
Hi all!
Im trying to run paraFoam to see a mesh, the paraView program start but then I get an error message:
line 57: 3852 memory acces error
I am using paraFoam 1.2 in Fedora 4 and paraView 2.2
Have somebody experience with?
Thanks
Alejandro
alejo is offline   Reply With Quote
Old   February 24, 2006, 10:59
Default Hi again, this error is also
Alejandro Arrieta
Hi again,
this error is also comming:
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/dm2/henry/OpenFOAM/Open FOAM-1.2/applications/utilities/postProcessing/graphics/PVFoamReader/PVFoamReade r/vtkFoamReader.cxx (214)
Changing case is not currently supported.
Please delete reader and create a new one for the new case.
ErrorMessage end
Any sugestion?
Old   July 15, 2006, 07:02
Default hi.. the following is the err
Sreekanth Kolan
sreekanth is on a distinguished road
hi..
the following is the error message i get when i try to open paraview. My aim is to plot stream lines for backward facing step flow. can some one tell how to do that with lines/points/ribbons instead of tubes.
also i need help regarding this error. i tried reinstalling but still ended up with same error. so, plzzzzz help me as soon as u can
newton{skolan,53}% ErrorMessage
# Error or warning: ERROR: In ../../../../../paraview-2.4.2/Utilities/VTKClientServer/vtkClientServerInterpret er.cxx, line 866
vtkClientServerInterpreter (0x80664b8): Cannot find module "libPVFoamReader.so". The following paths were searched:
/home/reynolds/skolan/OpenFOAM/linux/paraview-2.4.2/lib/paraview-2.4
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/lam-7.1.1
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/l ib
/home/user/skolan/OpenFOAM/linux/gcc-4.1.0/lib
/home/user/skolan/OpenFOAM/skolan-1.3/lib/linuxGcc4DPOpt
/usr/local/lib
/home/user/skolan/OpenFOAM/linux/paraview-2.4.2/lib
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/src/lam-7.1.1/platforms/linuxGcc4DPOpt/b in
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxGcc4DPOpt /bin
/home/user/skolan/OpenFOAM/linux/j2sdk1.4.2_05/bin
/home/user/skolan/OpenFOAM/linux/gcc-4.1.0/bin
/home/user/skolan/OpenFOAM/skolan-1.3/applications/bin/linuxGcc4DPOpt
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/wmake
/home/user/skolan/OpenFOAM/OpenFOAM-1.3/bin
/usr/X11/bin
/usr/local/bin
/usr/bin
/bin
/etc
/local/Tecplot10.0//bin
/home/user/skolan/OpenFOAM/linux/paraview-2.4.2/bin
/usr/lib
/usr/lib/vtk
/usr/local/lib
/usr/local/lib/vtk
ERROR: In ../../../../../paraview-2.4.2/GUI/Client/vtkPVXMLPackageParser.cxx, line 677
vtkPVXMLPackageParser (0x88475d8): Error loading Library component PVFoamReader
ErrorMessage end
sreekanth is offline   Reply With Quote
Old   July 15, 2006, 07:03
Default forgot to tell u guys that i a
Sreekanth Kolan
forgot to tell u guys that i am working on inux machine
Old   July 17, 2006, 12:44
Default The libPVFoamReader.so should
Mattijs Janssens
mattijs is on a distinguished road
The libPVFoamReader.so should be in your installation in:
Try re-extracting this library from the binary packs or rebuild it from the sources (bit tricky)
mattijs is offline   Reply With Quote
Old   July 18, 2006, 06:06
Default I tried rebuilding and i got t
Sreekanth Kolan
I tried rebuilding and i got the same error, for which i don't the reason. can you please help me rebuild it from sources. Just tell me the steps i need to follow.
Also i need to give parabolic inlet profile for which i need to define some variables. Where am i supposed to define those variables. Also where do i give the expression for inlet profile....is that in the 0/U file. Please reply as soon as possible.
thanks for your earlier reply
Old   July 18, 2006, 13:22
Default Just use the pre-compiled bina
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Just use the pre-compiled binaries from the OpenFOAM webpage. It works out of the box for everyone.
Search the Postprocessing/ParaFOAM forum for paraview problems with streamtracers and you should be able to figure out what is wrong.
There is also another thread in the Running/Solving CFD section dealing with Parabolic velocity profile inlets (including source code). Please search the forums before posting. It saves a lot of time for everyone.
msrinath80 is offline   Reply With Quote
Thread Tools
Trackbacks are On
ParaView Postprocessing problems with cyclic boundaries christian OpenFOAM Paraview & paraFoam 10 June 26, 2009 05:49
Installation problems about Paraview and PV3foamreader clark_liang OpenFOAM Installation 1 January 12, 2009 07:05
Problems using paraview 244 under open FOAM 141 or 13 sergio OpenFOAM Paraview & paraFoam 0 March 13, 2008 14:52
Problems with paraView alejo OpenFOAM Pre-Processing 0 February 17, 2006 08:24
Problems with Paraview evgenii OpenFOAM Paraview & paraFoam 2 November 23, 2005 08:35
