Home > Forums > OpenFOAM Paraview & paraFoam
FoamToVTK problem
Old   July 11, 2006, 09:19
Default Hi everybody, I have writte
Michael Oevermann
oevermann is on a distinguished road
Hi everybody,
I have written a new boundary condition (a new FvPatchField) for a time dependent inlet velocity. Everything with running the solver works fine. However, when I do a foamToVTK I get the following error
--> FOAM FATAL IO ERROR : keyword U is undefined in dictionary "/home/oevermann/OpenFOAM/oevermann-1.1/run/tutorials/myTurbFoam/blende/3.6e-05/ U_0::inlet"
Actually, I have no idea were to look first and what's going wrong here.
I don't see fundamental difference in terms of the output files if I run the solver just with a fixedValue inlet or my own routine.
Any ideas from the experts here? Thanks!
Michael
oevermann is offline   Reply With Quote
Old   July 11, 2006, 09:24
Default Your input and output function
Hrvoje Jasak
Your input and output functions are not compatible: the stuff that you wrote into the dictionary is not consistent with read in in the constructor from the dictionary.
Hrv
Hrvoje Jasak
Old   July 11, 2006, 09:54
Default Hrvoje, that's what I assum
Michael Oevermann
Hrvoje,
that's what I assumed. However, I don't see the inconsistency. The constructor from the dictionary looks
harmonicInletOutletFvPatchVectorField::harmonicInl etOutletFvPatchVectorField
const fvPatch& p,
const vectorField& iF,
const dictionary& dict
mixedFvPatchVectorField(p, iF),
UInf_(dict.lookup("U")),
pInf_(readScalar(dict.lookup("p"))),
omega_(readScalar(dict.lookup("omega"))),
phase_(readScalar(dict.lookup("phase")))
if (dict.found("value"))
and the write function
// Write
void harmonicInletOutletFvPatchVectorField::write(Ostre am& os) const
fvPatchVectorField::write(os);
writeEntry("value", os);
Do I need to write all private data read in by the constructor? If yes, how can I do that (just writeEntry("UInf_",os) ?)
Greetings
Michael
Old   July 11, 2006, 10:00
Default Well, (excuse the tone) you ar
Hrvoje Jasak
Well, (excuse the tone) you are dealing with a compiler, not a crystal ball: how would the write() function know that it needs to write out U, p, omega and phase? There is nothing anywhere in the software to tell the compiler this needs to be done, so it is not. If you look at the offending boundary dictionary, you will see that the data is not there.
You need some lines like:
amplitude_.writeEntry("amplitude", os);
Please adjust as necessary - I've picked this one from a similar piece of code.
Enjoy,
Hrv
Hrvoje Jasak
Old   July 11, 2006, 11:53
Default Hi Hrvoje, thanks for the hin
Michael Oevermann
Hi Hrvoje,
thanks for the hint! Some lines like
os.writeKeyword("U") << UInf_ << token::END_STATEMENT << nl
have fixed the problem.
I don't think that my initial problem/question had anything to do with the compiler (and/or my knowledge about compilers which might or might not not be as good as yours) - it is just a matter of how the classes in Foam are designed. It is not obvious at all that the write routine of a patch should write exactly the data read and indeed, the solver has no problems with it. It is the postprocessing requiring that and it is not documented anywhere (well, it might be documented but I didn't find it).
Greetings from Berlin
Michael
Old   July 11, 2006, 13:56
Default Hi Michael, Hmm, on C++ kno
Hrvoje Jasak
Hi Michael,
Hmm, on C++ knowledge I rate myself somewhere up there with Yoda, so I will take up the challenge:
If I design a class in a hierarchy and add an unknown number and type of private data into a final derived class, which may be in a form of a value member, a static or a reference, can you create a form of the base class (which clearly does not see the derived private argument types) to handle derived class I/O automatically?
The only form I can suggest is to template on the base with member types as arguments, which brings in the story of elipsis in the template argument list, and that's definitely not standard C++.
The post-processing requirement is a "value" entry in the patch field dictionary, which is indeed handled automatically, by calling the write function from the virtual base.
Can you enlighten me?
Hrv
Hrvoje Jasak
Old   July 11, 2006, 15:10
Default Hrvoje, sorry, but I cannot e
Michael Oevermann
Hrvoje,
sorry, but I cannot enlighten you :-(
Your last sentence was just the answear I hoped for in my initial question. Your class design makes perfect sense and I agree there is no solution for
automated class I/O here.
Thread Tools
Trackbacks are On
Strange foamToVTK problem hsieh OpenFOAM Running, Solving & CFD 4 January 4, 2009 01:03
Problem with channeloodles and foamToVTK farbfilm OpenFOAM Running, Solving & CFD 0 October 31, 2008 06:28
FoamToVTK and MayaVi alexandrepereira OpenFOAM Post-Processing 57 August 11, 2008 04:15
FoamToVTK output names hartinger OpenFOAM Post-Processing 2 March 29, 2007 06:49
FoamToVTK error with OF 13 melanie OpenFOAM Paraview & paraFoam 1 May 22, 2006 04:40
