Home > Forums > OpenFOAM Paraview & paraFoam
Turbulent intensity and viscosity ratio
Old   June 30, 2006, 13:15
Default Hi, What is the best way to
Greg Zink
gzink is on a distinguished road
What is the best way to visualize contours of turbulent intensity and viscosity ratio in paraFoam? Does this require adding code in Foam itself, or is there a way in paraFoam to calculate them from k and epsilon?
Thanks!
Greg Z.
gzink is offline   Reply With Quote
Old   June 30, 2006, 17:10
Default Easiest to add code in Foam -
Gavin Tabor
grtabor is on a distinguished road
Easiest to add code in Foam - either to your main code (add extra fields) or write a post-processing code to read in k,e and write out TKE and viscosity ratio.
I doubt that its possible in paraFoam
Gavin
grtabor is offline   Reply With Quote
Thread Tools
Trackbacks are On
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 05:49
Backflow Turbulence Intensity & viscosity ratio? Remy FLUENT 0 March 7, 2008 05:50
turbulence intensity and viscosity ratio Farhat FLUENT 2 July 3, 2007 08:43
Question...Turbulence Intensity & Viscosity ratio Jay FLUENT 1 October 6, 2005 04:41
turbulent viscosity limited to viscosity ratio of Hua FLUENT 6 April 24, 2003 16:45
