Home > Forums > OpenFOAM Paraview & paraFoam
PolyMesh Question
Old   June 19, 2006, 10:13
Default In regards to a simulation tha
Terry Jordan
tj22 is on a distinguished road
In regards to a simulation that has a mesh that changes with time. If the only instance of polyMech occurs in the constant folder then that mesh is used for the whole simulation. And if there is an instance of polyMesh within each time then the mesh is reloaded each time step.
My question is if there is a polyMesh in constant and one in time step 1, do I use the mesh from constant or from timestep 1 for my other timesteps?
Or is it impossible for this to happen?
Thanks.
tj22 is offline   Reply With Quote
Old   June 19, 2006, 10:26
Default Hi Terry, I hope this can b
Tommaso Lucchini
lucchini is on a distinguished road
Hi Terry,
I hope this can be helpful....
CASE 1
startTime 0;
no mesh in 0/polyMesh
the solver will create the mesh from constant/polyMesh
CASE 2
startTime 1;
no mesh in 1/polyMesh
CASE 3
startTime 1;
mesh defined in 1/polyMesh
the solver will create the mesh from 1/polyMesh
Regards.
Tommaso
lucchini is offline   Reply With Quote
Old   June 19, 2006, 11:06
Default I need to clarify my question.
Terry Jordan
I need to clarify my question. I am not running the simulations I am using the visualizing the results in paraview using a reader I am writing, so I know the following:
There will be a polymesh in constant.
There can be a polymesh in the time steps.
My question is if there is a polymesh dir in constant and say time step 1 and none in the others. For say, time step 3 do I use the polymesh instances from timestep 1 or constant?
Or is it not possible to have polymeshes at random time steps ie if there is a polymesh directory in timestep 1, there will also be one in 2,3,4..etc?
Thanks.
Old   June 19, 2006, 11:49
Default For this purpose, just think o
Eugene de Villiers
eugene is on a distinguished road
For this purpose, just think of constant as time = -1
The mesh from the most recent timestep will generally be used (unless specified otherwise).
It is possible to have polyMeshes in any combination of timesteps and/or constant. The above still holds.
eugene is offline   Reply With Quote
Old   June 19, 2006, 15:33
Default In which file is that specifie
Terry Jordan
In which file is that specified?
Old   June 20, 2006, 02:32
Default The current time is specified
Mattijs Janssens
mattijs is on a distinguished road
The current time is specified normally by system/controlDict (for OF applications) or by the time slider (in the ParaFoam reader).
From there it searches backwards for the first time directory containing polyMesh/points (those are the new points, i.e. geometry) and same for polyMesh/faces (and from this it reads the topology - owner,neighbour,faces,points,boundary). They can be different!
mattijs is offline   Reply With Quote
Old   June 20, 2006, 07:14
Default So the points can reside separ
Terry Jordan
So the points can reside separately at one time say "constant" and the other attributes (faces, owner, neighbor, boundary, cellzones, pointzones, and facezones) will reside together at another time say timestep 1?
Old   June 21, 2006, 03:21
Default No, but the other way round ca
Mattijs Janssens
No, but the other way round can: the geometry ('points') is 'newer' than the topology.
Basically if the mesh is moving we only write out the 'points' file but if the mesh topology is changing we write out all the files (including points)
Old   June 21, 2006, 08:15
Default OK. Thanks.
Terry Jordan
OK. Thanks.
Thread Tools
Trackbacks are On
Polymesh cells file missing fabrizio Open Source Meshers: Gmsh, Netgen, CGNS, ... 15 October 30, 2008 10:07
Blender Calculix he8 polyMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 3 October 2, 2008 11:33
Basic geometric operations on polyMesh like intersections bfa OpenFOAM Running, Solving & CFD 1 March 14, 2008 06:26
Question to UDF Claud FLUENT 1 April 10, 2007 17:02
question about LES gino briganti FLUENT 3 June 27, 2005 06:05
