-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Question about visualizing XYPlot (http://www.cfd-online.com/Forums/openfoam-paraview/61271-question-about-visualizing-xyplot.html)
tangd June 8, 2006 04:18
If I use "Filter->Probe" in Pa
If I use "Filter->Probe" in ParaView, then choose "Point" in "Probe Object", I can only see for example a point showing up in the plot(temperature as y axis, time as x axis). But how can I see the temperature curve of this point within a time interval, say 0~0.001s? Thanks!
hemph June 8, 2006 04:42
Hi Dihao. Plots of values ov
Hi Dihao.
Plots of values over time are not possible in the 2.4.2-version of version of paraview I believe. The cvs-version has temporal plots, so it is soon to come. Your best bet is probably to either create probes in OpenFOAM, or to use vtkProbes on your converted dataset (if you are familiar with VTK).
--Rasmus
tangd June 8, 2006 06:11
Thank you Rasmus. Unfortunat
Thank you Rasmus.
Unfortunately, I'm not familiar with VTK at all. I'm wondering how to create probes in OpenFoam, sorry I'm not familiar with this functionality either. Could you please give me further tips? Thank you!
hemph June 8, 2006 06:42
I have not used it myself, but
I have not used it myself, but there is a sample-utility in OF for probing a data field. Take a look in the User Guide on "Sampling data for plotting graphs".
tangd June 8, 2006 09:25
Thank you for your helpful inf
Thank you for your helpful information. I will have a try.
