Home > Forums > OpenFOAM Paraview & paraFoam
Visualisation of components of a vectorField
Old   May 29, 2006, 09:23
Default Hi! I define a plane in my
Nico Petry
nico is on a distinguished road
Hi!
I define a plane in my geometry and want to visualize the velocity with arrows in this plane. No problem so far. But I dont want to see the component of the velocity normal to the plane. Is it possible to show only let me say the x and y component and to remove the z component?
Thanks
nico is offline   Reply With Quote
Old   May 29, 2006, 09:49
Default You can do it easily with para
theof
You can do it easily with paraview. Select your cutting plane and apply the filter Surface Vector, selecting the option Parallel. Then apply the filter Glyph and set as input the Surface Vector. You should then see only the parallel component of your vector field on the cutting plane.
theofane
Thread Tools
Trackbacks are On
VOF visualisation help. Juan FLUENT 1 June 16, 2008 07:36
Bug in vectorField hjasak OpenFOAM Running, Solving & CFD 1 September 7, 2007 08:09
Visualisation Noel Rycroft Main CFD Forum 3 October 22, 2000 06:42
Visualisation of baffles! Anders Jönson CD-adapco 1 August 9, 2000 01:31
FAST/Visualisation Chris Robinson Main CFD Forum 3 December 3, 1999 01:56
