May 17, 2006, 13:14 |
Polyhedrons
Terry Jordan
I have added polyhedron support to my reader. I am visualizing the icoDyFoam/mixer2D set. When I look at it in paraFoam it looks correct and perfoms nicely. How are you handling the polyhedrons? I dont think paraFoam is using vtkconvexpointset.
I used convexpointset which is extremely slow and also does not make sense when looking at the wireframe like it does in parafoam. (in parafoam the center region looks like blades) Is this mesh intended to be viewed as polyhedron? Or do the polyhedrons need to be decimated like they are in parafoam? Thanks. |
May 17, 2006, 13:32 |
We decompose the polyhedra. Is
Mattijs Janssens
Rep Power: 26 |
We decompose the polyhedra. Is not a good way since creates large numbers of pyramids and tets so any ideas to do it better are welcome
May 17, 2006, 15:14 |
I found a problem in my code.
Terry Jordan
I found a problem in my code. It looks fine now. I use vtkconvexpointset, which preserves the polyhedra, but it is very slow. Thanks.
[Salome] DAT file from Salome for use with Foam. | massive_turbulence | OpenFOAM Meshing & Mesh Conversion | 1 | May 3, 2017 04:49 |
