Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to zoom in only a region of my geometry
Old   April 10, 2006, 15:09
Default How to zoom in only a region of my geometry
Nico Petry
nico is on a distinguished road
Hi
my problem is that my geometry exist of a porous region and a "normal" navier stokes region. So if want to visualise the vecolity i got the following problem. Either i can't see anything in the porous region because the velocity in this region is very very low or i take bigger arrows and cant see anything because then they are m uch too big in the ns region. So how is it possible to zoom in only a part of my geometry?
Thanks
nico is offline   Reply With Quote
Old   April 10, 2006, 16:44
Default Two ways that I can think of (
Assistant Moderator
Bernhard Gschaider
Two ways that I can think of (depending on how you specify the porous region)
1. Assuming you have a field filter that is 1 in the porous region and 0 elsewhere: in paraFoam use the Calculator-filter and specify a new (cell based) vector-field U*filter. These should give you OK cell-values, but for vectors paraFoam will insist on interpolatin it to the vertices (and propably the values at the porous/free-interface will be wrong)
2. The porous region is specified by a cellSet: use foamToVTK with the -cellSet option to write out the data just for that cellSet and view the data with paraview (or import it into paraFoam in addition to the normal case data)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 10, 2006, 16:50
Default I should think before posting:
Assistant Moderator
Bernhard Gschaider
I should think before posting: there is a simpler way for the first option (the one with the filter-field): Use the Threshold-filter of paraFoam with values that are only valid in the porous material (in my example 0.5 < filter < 1.5). Voila: You get exactly what you want.
Old   April 11, 2006, 02:41
Default Thank you very much for your f
Nico Petry
Thank you very much for your fast answer!
bye Nico
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
