Home > Forums > OpenFOAM Paraview & paraFoam
Could anyone please help me in running the paraview in my Ubuntu system
Old   February 3, 2006, 12:23
Default Hi all I am trying to run a tu
Hi all I am trying to run a tutorial called cavity
in icoFOAM directory and when I type
$ paraFoam $FOAM_RUN/tutorials/icoFoam cavity
$ paraFoam /project/foam/OpenFOAM/foam-1.2/run/tutorials/icoFoam cavity
I am getting
line 57: paraview: command not found
what can I do to run my paraFOAM can you all please help me because I am learning the OpenFOAM to complete my masters project in time.
Thanks all
chandra s kothamasu
Old   February 3, 2006, 12:30
Default > line 57: paraview: command n
stefanke is on a distinguished road
source your shell (for details consult the readme file of OpenFoam). After doing this your system should be able to find paraview (if you installed it correctly)
stefanke is offline   Reply With Quote
Old   February 6, 2006, 10:13
Default thanks for the help i will con
thanks for the help i will consult my supervisor regarding that.
thanks once again stefan
Thread Tools
Trackbacks are On
PARAVIEW from C code: system(...) simone Marras ParaView 6 February 26, 2007 13:30
running Fluent on a DUAL CORE system Ralf Schmidt FLUENT 3 June 20, 2006 10:21
HI all I cant find display button in paraview when i execute cavity tutorial there is only parameter button in the paraview chan OpenFOAM Paraview & paraFoam 2 February 13, 2006 08:37
Problem running paraFoam paraview command not found spdracer22 OpenFOAM Pre-Processing 2 December 7, 2005 06:32
Installation on a cluster running a queueing system PBS sampaio OpenFOAM Installation 12 June 20, 2005 17:16
