How to get density color plot in twoPhaseEulerFoam
Hi.
I have a question about postprocessing twoPhaseEulerFoam. I want to look at density color plots but the only variables are alpha, epsilon, k, p, Theta, Ua and Ub. Is there a way to see density profile? Regards, |
Currently no.
You need to a
Currently no.
You need to add that to the code if you want it. However, each phase has a constant density so it would look exactly the same as the alpha field (if you calculated the density by linear interpolation) But with a different value. |
I am using twoLiquidMixingFoam, where the density and viscosity are functions of concentration. I am wondering how would I display the density and viscosity fields in paraview. In other words, how to write the code to do that. Thanks. |
