Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Visualizing data 2 metres above ground
Old   July 1, 2005, 16:23
Default Visualizing data 2 metres above ground
David Segersson
segersson is on a distinguished road
I have to plot data x metres above a curved surface. To do this I would like to either create an isosurface on distance from the curved surface and then display the data on it, or better, transform a copy of the curved surface x metres and then display data on it.
However, I have not managed to plot coordinate values at all, even if geometric data have to be available for the mesh.
Does one have to create a volScalar field with coordinate values to be able to operate on them, or is there any other way?
Thanks
David
segersson is offline   Reply With Quote
Old   July 1, 2005, 18:43
Default Compile and run this on your c
Eugene de Villiers
eugene is on a distinguished road
Compile and run this on your case:
wallDistance.tgz
It will create a wall distance field and write it to your current time directory.
eugene is offline   Reply With Quote
Old   July 6, 2005, 12:19
Default Thanks a lot, I will try it!
David Segersson
/David
problem with exporting data to Tecplot v.jab OpenFOAM Post-Processing 2 January 11, 2017 08:56
[OpenFOAM] saving data in paraview aylalisa ParaView 3 May 31, 2014 11:38
[General] Warping Cells by Vectors? ronwelty ParaView 10 April 29, 2014 05:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
