[OpenFOAM] ParaView Crashes During OF-case Load |
April 7, 2009, 13:21 |
Bill Rosemurgy
Rep Power: 16 |
When I try to open a case using paraFoam, ParaView crashes with this error mesage: terminate called after throwing an instance of 'std::length_error' what(): basic_string::_S_create /Volumes/openFOAM/OpenFOAM-1.5.x/bin/paraFoam: line 81: 6515 Abort trap $ParaViewPath --data=$caseFile Likewise, if I start ParaView from the terminal and then load the controlDict as an openFOAM file, it loads but then when I click on "Apply" I get this error: paraview(6537,0xa0260720) malloc: *** mmap(size=1073741824) failed (error code=12) *** error: can't allocate region *** set a breakpoint in malloc_error_break to debug terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc Abort trap They seem to be two entirely different errors but any help on either of them would be appreciated. I get these errors running both PV3.3 and PV3.4 on my MacBook Pro using OF-1.5.x. Thanks, Bill |
Display Modes | |
[General] Paraview crashes with segmentation fault when using meshes larger than 50M | Ricardo1992 | ParaView | 0 | September 13, 2018 06:20 |
OpenFOAM programming to load certain number of case files it-self? | Ash Kot | OpenFOAM Programming & Development | 7 | February 28, 2017 04:42 |
simpleFoam 3D case: crashes after 7 cycles | alvariten | OpenFOAM Running, Solving & CFD | 20 | July 3, 2015 10:41 |
TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6 | hemph | OpenFOAM | 3 | December 5, 2009 05:19 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
