June 11, 2009, 05:32 |
Paraview Cp Plot
Prapanch Nair
Rep Power: 17 |
I have the FOAM results for a external flow problem ( 2 D). I want to see the plot of Cp around the object. How do I do that using paraview?
I tried to open the object patch and use plot over line on it. But the line is a straight line. Is there a way to conform a line over the object's surface and then plot Cp along that line? How do I do this in 3D. Is there another way in OpenFoam to obtain Cp over a object? Thank you Prapanj. |
coefficient of pressure, openfoam, paraview |
[OpenFOAM] Plot over line average magnitude of particle velocity in paraview | maysmech | ParaView | 13 | August 12, 2022 11:46 |
[OpenFOAM] How to plot flow rate over time with Paraview | sekunda | ParaView | 17 | July 23, 2020 13:14 |
Vector Plot without using paraView | DominicTNC | OpenFOAM Post-Processing | 1 | August 25, 2017 04:11 |
Different results using sample utility vs Paraview 'Plot over line' tool | agarwa58 | OpenFOAM Post-Processing | 5 | March 20, 2016 08:57 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
