[OpenFOAM] basic question contour plot in paraview |
March 13, 2010, 12:17 |
cathren
Rep Power: 16 |
Dear all,
How can I plot a data as a contour plot with paraview, actually I was successful to upload my data, then what I need to do for the parameter to show the plot? please help me |
March 14, 2010, 01:10 |
Alan Russell
Rep Power: 16 |
Kate, Since you didn't specify exactly what you're trying to do, here are some things to look try:
1. In the Cavity tutorial, you look at pressure contours by moving to the time of interest then in the active variable controls, you select 'color by p'. There are two choices - the cube icon gives one value per cell and the circle icon interpolates pressure values. 2. Make a slice through your domain and use the contour tool (the half dome icon or Filters-Common-Contour from the drop down menus). You will need to click 'New Range' in the object inspector to define a range (or set your own range by adding values). The display tab will let you change the color scheme 'color by.' 3. There is a user guide for ParaView at their website www.paraview.org/files/v1.6/ParaViewUsersGuide.PDF. Some features are explained better than others - the tutorials at the end are well written. You need to download the dataset for the tutorials from the same website. Good luck, Alan |
March 14, 2010, 11:57 |
cathren
Rep Power: 16 |
Thanks alot for your help, I will have a look at the attached file,
actually my question seems to be basic, I want a contour plot for data formatted as a VTK format as in the attached file. I was successful to upload my data file in paraview, I pressed accept buttom, but it does not show any plot, how can I change the setting for the parameters to suit my data file . which options should I follow to see the plot. tha data is points x, y generated as a triangular mesh, I need to plot it againest the value of the solution at this point, it may be helpful if you could look at the attached file and try with it. will I be able to save image in the dispaly area as eps or ps file?? because in the user guide it says Supported image file formats are Windows Bitmap (*.bmp), JPEG (*.jpg), PNG (*.png), binary PPM (*.ppm), and TIFF (*.tif).looking for your help wishes Kate Last edited by Kate; March 14, 2010 at 12:31. |
March 14, 2010, 15:46 |
Sandeep Menon
Rep Power: 25 |
I seemed to be able to open the file just fine.
I loaded the VTK file using File->Open... |
March 14, 2010, 15:57 |
#5 | |
cathren
Rep Power: 16 |
looking for help |
March 14, 2010, 16:03 |
Sandeep Menon
Rep Power: 25 |
Which version of paraview are you using? On ParaView 3.6.1, select Open from the File menu, select the file on your system, and click Apply. Nothing else to it.
March 14, 2010, 16:10 |
#7 | |
cathren
Rep Power: 16 |
PHP Code:
wishes Kate Last edited by Kate; March 15, 2010 at 08:05. |
July 23, 2020, 14:05 |
plot contour paraview
Asmaa
Rep Power: 10 |
For contour plot, check this video: https://youtu.be/fnawxr0WLJU
[OpenFOAM] Plot over line question | RodriguezFatz | ParaView | 9 | April 28, 2017 07:19 |
[OpenFOAM] Plot over line fails in ParaView | mheinz | ParaView | 4 | May 23, 2016 05:28 |
generating 2d-planar contour plots from a contour plot on a curved surface | alinik | CFX | 3 | May 21, 2016 06:17 |
[OpenFOAM] Problem with contour plot of calculator in Paraview | lcbuijs | ParaView | 0 | July 27, 2015 08:58 |
[OpenFOAM] How to create an contour plot for arbitrary plane with interpolated data | navaladi | ParaView | 0 | June 4, 2008 07:57 |
