Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] problem of mesh of paraview
Old   September 14, 2009, 03:14
Question problem of mesh of paraview
Heintz Simon
sheintz is on a distinguished road
Send a message via MSN to sheintz Send a message via Skype™ to sheintz
I generate a mesh with StarCCM+ and I convert this mesh with ccm26ToFoam.
But when i see the mesh of ParaView, it's not the same mesh (some cells are cut but I have the same number of cell with openfoam and starccm+, look at the picture of http://img11.imageshack.us/img11/2034/netzvergleich.jpg).
Is there a problem for the presentation in paraView ? Must I check a option in this software ?
I thank you
Best regards
Simon Heintz
sheintz is offline   Reply With Quote
Old   September 14, 2009, 11:27
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
The std openfoam reader module for paraview do not display polys correctly.
use foamToVTK and open paraview and load the generated .vtk file which will be in a folder under your case called VTK.
Best regards
linnemann is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[OpenFOAM] snappyHexMesh - can't open mesh in ParaView tfigueiro ParaView 0 June 11, 2015 19:05
Mesh is doing some problem prwl120 FLUENT 2 May 21, 2015 14:05
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 18:07
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
