Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Distributed ParaView and PV3FoamReader
Old   April 1, 2010, 05:07
Default Distributed ParaView and PV3FoamReader
Luca Micali
micalil is on a distinguished road
Hi all,
I've searched the whole forum at large but I did not find anything about my issue, so I'm opening a new thread.
My target is to run ParaView on a machine, pvserver on another, and read directly OpenFOAM data.
ParaView alone works fine, loads correctly libPV3FoamReader.so and libPV3FoamReader_SM.so and opens as well everything I throw at it.
pvserver, on the contrary, starts fine and I can connect to it via "File->Connect" from ParaView as well, but looking at "Tools -> Manage Plugins/Extensions" the "Remote Plugins" pane is empty.
Using the original PV3FoamReader code from OpenFOAM 1.6 package and trying to open anyway an OpenFOAM case leads to a crash of both pvserver and ParaView.
Using the PV3FoamReader code pulled from GIT repo today (4/1/2010) shows the same situation for "Remote Plugins" information, but when trying to open anyway an OpenFOAM case there are no more crashes: ParaView just freezes.
When trying to add manually via the "Load Plugin" feature, I get an undefined symbol error for libPV3FoamReader_SM.so, and "This is not a ParaView plugin" for libPV3FoamReader.so.
Did someone encounter the same kind of problem? Or, even an easier question, did someone already tried to use pvserver this way with any success?
Thanks in advance,
Luca Micali
------ Versions of software
Redhat Enterprise Linux 4.6 em64t
OpenFOAM 1.6 using ThirdParty 1.6 compilers
ParaView 3.6.1
PV3FoamReader pulled today from GIT
Major details on request
micalil is offline   Reply With Quote
Old   June 30, 2010, 09:45
Sebastian W
naval is on a distinguished road
Hi there,
I am currently trying to do the same thing, so far without success.
Did you ever manage to get it running?
Cheers,
naval
naval is offline   Reply With Quote
Old   June 30, 2010, 09:53
Luca Micali
Sorry to say it, naval but I found no way to make it work. I'm even thinking it's just not possible (as of April 1st).
Old   June 30, 2010, 10:19
Sebastian W
Thanks a lot for this remarkably quick reply.
I'll let you know, if I stumble upon a solution somehow.
Cheers,
naval
Old   July 1, 2010, 05:09
Takuya OSHIMA
7islands is on a distinguished road
In case you're unaware, did you try the built-in reader in ParaView 3.8?
(Run "touch case.foam" in your case directory, setup client/server, open case.foam from PV)
T
7islands is offline   Reply With Quote
parafoam, paraview, pvserver
Compiling Paraview 3.12.0 and the PV3FoamReader Module smpark OpenFOAM Installation 2 January 9, 2012 07:16
Paraview not found fusij OpenFOAM Installation 2 January 1, 2011 20:44
ParaView Stopped Working AlanR OpenFOAM 5 April 17, 2010 04:55
Compiling paraview 33 and pv3foamreader module mcjicpm2 OpenFOAM Installation 1 March 19, 2009 10:59
Installation problems about Paraview and PV3foamreader clark_liang OpenFOAM Installation 1 January 12, 2009 06:05
