Home > Forums > OpenFOAM Paraview & paraFoam
Problem with parafoam on ubuntu 9.10 machine
Old   December 26, 2009, 00:12
Default Problem with parafoam on ubuntu 9.10 machine
Nabeel
nabeels is on a distinguished road
Hello Foamers
I have installed openFOAM 1.6 on a machine running with ubuntu 9.10 with no compilation problems. As an example, when the cavity problem was run, I was able to see the progress of the solution till it ended successfully.
Unfortunately, when I came to view the results, nothing appeared in paraview when parafoam was executed . I was able to see the meshed domain (before calling the solver icofoam) but not the results. The version of paraview used is 3.6.1. I used vtk files to load them into paraview and they failed due the following error:
p, li { white-space: pre-wrap; } ERROR: In /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/IO/vtkXMLParser.cxx, line 484
vtkPVXMLParser (0x39c02e0): Error parsing XML in stream at line 1, column 1, byte index 1: not well-formed (invalid token)
Root does not exist. Either state file could not be opened or it does not contain valid xml
vtkPVXMLParser (0x2f5cc40): Error parsing XML in stream at line 1, column 0, byte index 0: not well-formed (invalid token)
Any idea how to solve this problem with paraview?
nabeels is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem with UDF on a Linux machine (Red Hat) Iaroslav Fluent UDF and Scheme Programming 5 May 12, 2010 07:43
Problem using paraFoam to view cavityGrade mesh file felik9 OpenFOAM Native Meshers: blockMesh 1 September 27, 2009 15:31
Problem with paraFoam (ubuntu 9.04) peb OpenFOAM Paraview & paraFoam 4 August 24, 2009 09:50
problem with paraFoam mauro ParaView 0 August 24, 2009 07:33
ParaFoam on Ubuntu 804 francy OpenFOAM Installation 6 May 8, 2009 06:57
