Home > Forums > OpenFOAM Paraview & paraFoam
Visualization with ParaView (in general)
Old   January 8, 2010, 13:28
Default Visualization with ParaView (in general)
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
My questions is not directly related to OpenFOAM, but to the usage of ParaView in CFD-Simulations in general.
What I want to know is how I can learn to visualize data with ParaView.
OpenFOAM uses the VTK-format? Is this applicabel to any kind of data?
I'm working with a selfmade CFD-code from a small company and they want to visualize their data with ParaView.
Have nice day. S.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   January 25, 2010, 08:17
sega's Avatar
Sebastian Gatzka
Hello, me again.
I had a quick look into the VTK.
Seems like there are well defined file formats for the creation of VTK-files, which can be read from inside ParaView.
How does the conversion from the OpenFOAM data structure to the VTK format work? This should be foamToVTK?
Just for basic understandung: This tool reads the data from OpenFOAM and writes it to the specific VTK-file-format?
Just to make sure: This is the only way of dealing with this?
If yes, then I know what to do: Write a code, which converts the data from our selfmade CFD-code into the VTK-file-format!
Have a nice day.
Old   January 26, 2010, 03:33
Mark Olesen
olesen will become famous soon enough
Originally Posted by sega View Post
... This tool reads the data from OpenFOAM and writes it to the specific VTK-file-format?
Note that the VTK files that OpenFOAM writes are the so-called 'legacy' format. The more modern XML-based VTK streaming formats are much more annoying to generate - I haven't bothered.
I would personally suggest writing Ensight format (ASCII and/or C binary) for your output instead. IMO this has several distinct advantages over using VTK files.
  • Paraview and VTK provide reasonable support for Ensight format.
  • Other visualization programs may also support Ensight format.
  • The Ensight format provides a native way of storing nfaced (polyhedral) cells that is currently impossible with VTK formats.
  • In the Ensight format, you can have a single time-invariant geometry with multiple time-varying field values. In the legacy VTK, you would need to store the geometry for every field, for each time. There is a paraview format that could avoid some of the redundant geometry, but then you definitely need to use the XML-based VTK formats.
As another alternative, you might also find it useful/interesting to see if a solution with XDMF/HDF5 might also work for your in-house CFD code.
olesen is offline   Reply With Quote
Old   January 26, 2010, 05:13
sega's Avatar
Sebastian Gatzka
Very interesting response, thank you for that.
I will have a look into the Ensight format.
As a matter of fact our code is using cubic cells exclusively, so basically I'm not in need of polyhedral cell support.
As I have mentioned this is the first step towards visualization.
Later our case contain of up to 2 million cells. In this case writing VTK-files and reading them into ParaView may not the right approach for obvious memory reasons. I have read something about "pipeline" visualization.
What is this? If the user wants to have a specific field visualization, ParaView communitcates via VTK with the data from our simulation?!
So there doesn't have to be a new (gigabyte) file of VTK-data?
Old   January 29, 2010, 10:05
sega's Avatar
Sebastian Gatzka
So, simple question again: How does OpenFOAM and Paraview communicate?
Are there temporary VTK files or is there a 'direct' communication?
I'm still not sure ...
Old   January 29, 2010, 10:39
Mark Olesen
One means is the reader module:
applications/utilities/postProcessing/graphics/PV3FoamReader/
This would, of course, be yet another means of solving your problem. Write a reader module to handle your in-house data format.
Old   January 31, 2010, 06:42
sega's Avatar
Sebastian Gatzka
Thank you olesen.
vtkPV3FoamReader.h looks like the only file worth looking at...
That can't be all?!
Old   February 1, 2010, 03:24
Mark Olesen
Thank you olesen.
That can't be all?!
Nope. IMO you need to look at and study all of them. The PV3FoamReader directory has the paraview server-manager plugin (this is where you'd have found the vtkPV3FoamReader.h header). The vtkPV3Foam directory contains the ''real" work - the transformation from OpenFOAM structures and data types into VTK.
Thread Tools
Trackbacks are On
welding sim visualization problems in Paraview Aorus ParaView 0 December 25, 2009 15:39
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
ParaView patch visualisation error in Development version philippose OpenFOAM Paraview & paraFoam 17 March 26, 2007 06:45
PARAVIEW Grid visualization simone Marras ParaView 2 January 23, 2007 09:05
