-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Cavity Tutorial: ParaView starts, cannot find reader (http://www.cfd-online.com/Forums/openfoam-paraview/72138-cavity-tutorial-paraview-starts-cannot-find-reader.html)
mfrain January 26, 2010 21:36
I am troubleshooting an installation of OpenFOAM 1.6 on Debian GNU/Linux 5.0. I am working through the instructions at http://www.openfoam.com/docs/README.php. The installation test script ran without errors and I have just run the cavity tutorial with the blockMesh and icoFoam scripts.
However, when I run paraFoam, I get the following messages in the console:
$ paraFoam
created temporary 'cavity.OpenFOAM'
Read float past end of buffer
ParaView starts, but a dialog box opens indicating a reader for '$FOAM_RUN/tutorials/incompressible/icoFoam/cavity/cavity.OpenFOAM' could not be found, and asks for a reader to be selected.
If I select the logical 'OpenFOAM Files' reader, ParaView crashes with the following additional messages to the console:
terminate called after throwing an instance of 'std::length_error'
  what():  basic_string::_S_create
/home/mfrain/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 109:  5730 Aborted                paraview --data="$caseFile"
If I select nothing and close the window, ParaView remains running but with no data input, and can exit normally.
I am guessing that ParaView is having difficulty seeing and/or interpreting the OpenFOAM files. Any guidance would be greatly appreciated.
EDIT:
Additional note: Building the PV3FoamReader per the OpenFOAM README does not change this behavior.
suitup February 12, 2010 12:00
Hi should be the same problem like in this thread http://www.cfd-online.com/Forums/ope...tu-9-10-a.html
Good luck.
mirko August 18, 2011 11:00
ParaView 3.10.1 starts, reader could not be found
Good luck.
I have a milder version of the problem:
I installed CentOS OF2.0.x and friends, including ParaView 3.10.1
paraFoam will launch ParaView, but ParaView cannot figure out which viewer to use and offers me a list of readers. When I select the OpenFOAM reader, ParaView proceeds normally.
I looked at the ParaView command line switches and the paraFoam script, and I don't see anything obvious.
Any thoughts?
Thanks,
Mirko
wyldckat August 18, 2011 11:52
Hi Mirko,
Since it's OF 2.0 + PV 3.10.1, try run it like this:
paraFoam -builtin
This will use the ".foam" internal reader that comes with ParaView.
As for the ".OpenFOAM" reader, it will depend on:
  1. Whether you built it yourself.
  2. Or came built with CentFOAM (which I think is no longer supported, but I could be wrong).
  3. Or is a version that comes with/for CentOS.
  4. Or is the pre-built one from www.paraview.org.
If you built it yourself, or if the version you have got comes with the development files, then you can build the official reader: the PV3FoamReader Module
Best regards,
Bruno
mirko August 18, 2011 12:27
Originally Posted by wyldckat (Post 320654)
Hi Mirko,
paraFoam -builtin
Best regards,
Bruno
thank you Bruno,
I downloaded all the files from the sourceforge site. They were updated on 8/3. I will contact the CentFoam folks about the paraview build.
Mirko
carowjp June 18, 2012 14:14
Hello Bruno,
I have a similar issue as described by Mirko:
$ paraFoamcreated temporary 'cavity.OpenFOAM'
However, I should say that I compiled Paraview 3.12.1 and the PV3Reader (OF 2.1.1) from the OpenCFD sources. I would like to have an install of OF 1.7.1 and OF 2.1.1 which both use a newer Paraview due to some bug fixes I require.
OF 1.7.1 and Paraview 3.8 works
OF 2.1.1 and Paraview 3.12.1 works
I tried to change .bashrc to allow use of OF 1.7.1 and Paraview 3.12.1 and that's when ParaView cannot figure out which viewer to use and offers me a list of readers. If I select the OpenFOAM reader, ParaView proceeds normally.
My challenge is that I am writing Python code to automate things and manually selecting a reader isn't so great!
thanks for any suggestions,
Jim
wyldckat June 18, 2012 14:57
Greetings Jim,
Mmmm... If I understand you correctly, you're trying to use ParaView 3.12.0 with OpenFOAM 1.7.1.
And according to your description, I suppose you can't have two separate terminal windows/tabs, one for each OpenFOAM, is that correct?
Another question: is the OpenFOAM 1.7.1 your own build as well?
Basically the solution should be, by doing the following steps on your OpenFOAM 1.7.1 installation:
  1. Edit the file "OpenFOAM-1.7.1/etc/apps/paraview3/bashrc".
  2. Find these lines and change 3.8.0 to 3.12.0:
    # set VERSION and MAJOR (version) variables
    ParaView_VERSION=3.8.0
    ParaView_MAJOR=unknown
  3. Save and close that file.
  4. Next, go to the folder "ThirdParty-1.7.1":
    foam3rdParty
  5. Do a full copy of the other installation of ParaView 3.12.0. For example:
    cp -r $HOME/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/paraview-3.12.0 platforms/linux64Gcc/
  6. Start a new terminal, with the normal OpenFOAM 1.7.1 environment.
  7. Build the official PV3FoamReader once again:
    foam
    cd applications/utilities/postProcessing/graphics/PV3FoamReader
    ./Allwmake
  8. If all goes well, the goose is now cooked and ready to serve :) (Sorry, dinner time ;)).
On the other hand, if you simply want the internal reader, then you can hack the paraFoam script and change all references of ".OpenFOAM" to ".foam". To know where paraFoam is, run:
which paraFoam
Best regards,
Bruno
carowjp June 18, 2012 22:14
Bruno,
The goose was delicious....I adjusted the paths in step 5 to match my install and all is good.
thanks alot,
Jim
