paraFoam crashes with channelFoam example
Hi All,
I am having a problem with paraFoam crashing that I am hoping someone can help with. When I try and step through the time steps after on the third one it crashes, even if I start at 4 and go to 5 and then 6. So I don't believe that it is anything to do with any particular time step. I am running it on a virtual machine that subsequently crashes too, so I have limited output from the crash, but the last few lines are as follows: From function messageStream::operator OSstream&() in file lnInclude/messageStream.C at line 203. FOAM aborting This seems to be very similar to a problem with foamToVTK discussed but not resolved at this thread: http://www.cfd-online.com/Forums/ope...foamtovtk.html I have watched the system monitor and it doesn't appear to be running out of memory. I am running OpenFOAM 1.6 on Kubuntu 9.10 and compiled paraFoam on my machine. |
Hej there!
I just encountered the same problem with the channelFOAM tutorial (for the first time) using paraview-3.8.0 on ubuntu-10.4. Everything works fine (even jumping to the last frame) but going through the time steps frame by frame makes paraview crash. Matthew, did you allready fix the problem? |
you need to add the header to each of the .xy files... it is missing for somereason.
