Paraview_data_root
Hey There,
i would like to post process things with ParaFoam. Unfortunately I figuered that my "python shell is not available" klicking on tools->pythonshell. I found that i could set "PARAVIEW_ENABLE_PYTHON" to true before compiling, but where? So I tried to use html for tools->record test. But when I reuse the script he complains that I did not save the screen shots in "PARAVIEW_DATA_ROOT". But where can I find "PARAVIEW_DATA_ROOT" or define it if it is not available? Thx & regards! |
Greetings heavy_user,
OK, it's as simple as pie... well, sort of. In the folder ThirdParty-1.6 you have a script named makeParaView and a link named makeParaView-python. Now, if you follow the instructions for building Paraview in OpenFOAM's README, but if instead of running: Code:
./makeParaView Code:
./makeParaView-python But don't forget to install python, before re-building Paraview!! And hopefully, the rebuild process will fix the problem you've had with: Quote:
Bruno |
Hi Bruno,
thanks a lot!! It was that easy :o !! (i have looked at some places, but NOT there :mad:) regards! Quote:
