Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraFoam does not show results of Cavity tutorial
Like Tree1Likes
Old   June 17, 2015, 12:51
Michu
michu is on a distinguished road
Hello Bruno,
Thank you for your response, it helped a lot. I think the manner of which I am using icoFoam was that it produced a initial condition and a final condition. I may have had too large of a time step and so the flow went from not developed at all to fully developed in one time step.
Thank you for your help!
~Michu
michu is offline   Reply With Quote
Old   October 7, 2020, 10:11
Talking Paraview problems :-(
  #22
joelle d'anna
MouseLab is on a distinguished road
Hi, I've read the thread and I did not find a solution for my problem.
I generated the mesh and on the terminal it works, but if I try to visualize it on paraview it does not be shown.
I got this message on the terminal:
Invalid $PV_PLUGIN_PATH and -plugin-path= not defined
No supplementary ParaView/OpenFOAM reader modules
Using builtin reader: paraFoam -vtk
I tried to run paraFoam -vtk , but I got the same result
Anyone can help me ?
thks
MouseLab is offline   Reply With Quote
cavity problem, parafoam
[OpenFOAM] Refresh Times does not seem to work (Cavity tutorial) MBttR ParaView 2 June 7, 2016 08:53
[OpenFOAM] icoFsiElasticNonLinULSolidFoam (foam-extend 3.1)>>How to see results with paraFoam? steven123 ParaView 7 December 5, 2015 02:34
[OpenFOAM] Open Sample results using paraFoam lpashwin ParaView 0 June 24, 2015 11:04
[OpenFOAM] Trouble running paraFoam in cavity tutorial sweisenb ParaView 2 October 10, 2014 15:56
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 09:53
