Home > Forums > Visualization & Post-Processing Software > ParaView
[General] How to make Paraview toolbar icon size larger?
Old   April 9, 2017, 22:08
Default How to make Paraview toolbar icon size larger?
ifiaxxy is on a distinguished road
After installing openfoam 4.1 with paraview 5.0.1 64 bit, I found that the icons are very hard to see. (attached pic)
Is there any way for me to increase the size of the icons?
I have tried to play with the display setting in the system settings, but that does not work.
When I close the paraview window, I get the following error message in the terminal: "Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!"
Not sure if this is relevant.
My system is Ubuntu 16.04 and laptop is XPS 13 developer edition.
Thank you for your help
File Type: jpg Screenshot from 2017-04-09 22-04-50.jpg (56.5 KB, 23 views)
ifiaxxy is offline   Reply With Quote
Old   June 20, 2019, 15:08
Josh Williams
JoshWilliams1996 is on a distinguished road
Did you find a solution to this?
JoshWilliams1996 is offline   Reply With Quote
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
How to make icon for starlaunch in SuSeLinux Elyor Siemens 3 March 20, 2007 12:06
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 16:45
how to make particle size distribution adma CFX 0 January 10, 2006 15:57
