-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   3D Z velocity profile in terms of r in Paraview (http://www.cfd-online.com/Forums/openfoam-paraview/80338-3d-z-velocity-profile-terms-r-paraview.html)
chegdan September 22, 2010 17:18
Hi All,
It must be late in the day as I am totally blank on how to get a Uz velocity profile as a function of radial position from a 3D simulation. For simplicity, assume the flow is in a pipe. I would like to get the averaged Uz velocity as a function of radial position over the entire length of the pipe so that I have a plot of Uz vs r. How can this be done in paraview? any help would be much appreciated and if I figure this one out I'll post the procedure.
JR22 October 8, 2014 16:12
Daniel,
I am having the similar problem, as I am trying to figure out how to measure average radial, angular, and vertical velocity on a mixing tank. I actually used Helyx-OS for preprocessing, and OF-2.3, with MRF steady state.
In paraview I thought of the following process (which I haven't been able to implement):
  1. Making a filled cylinder (with seed points),
  2. Resampling the dataset to that cylinder using its points as seeds
  3. Then exporting that data and calculating the velocities using R or some other software.
Thanks in advance,
Jose
If you found a solution, please let me know.
