[OpenFOAM] 3D Z velocity profile in terms of r in Paraview
Like Tree1Likes
  • 1 Post By chegdan
Old   September 22, 2010, 17:18
Default 3D Z velocity profile in terms of r in Paraview
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Hi All,
It must be late in the day as I am totally blank on how to get a Uz velocity profile as a function of radial position from a 3D simulation. For simplicity, assume the flow is in a pipe. I would like to get the averaged Uz velocity as a function of radial position over the entire length of the pipe so that I have a plot of Uz vs r. How can this be done in paraview? any help would be much appreciated and if I figure this one out I'll post the procedure.
JR22 likes this.
chegdan is offline   Reply With Quote
Old   October 8, 2014, 16:12
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Daniel,
I am having the similar problem, as I am trying to figure out how to measure average radial, angular, and vertical velocity on a mixing tank. I actually used Helyx-OS for preprocessing, and OF-2.3, with MRF steady state.
In paraview I thought of the following process (which I haven't been able to implement):
  1. Making a filled cylinder (with seed points),
  2. Resampling the dataset to that cylinder using its points as seeds
  3. Then exporting that data and calculating the velocities using R or some other software.
Thanks in advance,
Jose
If you found a solution, please let me know.
JR22 is offline   Reply With Quote
openfoam, parafoam, paraview, visualization
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
deviated velocity profile rayan24 Main CFD Forum 0 July 3, 2013 16:34
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
