[OpenFOAM] where is the "*.OpenFoam" File located? |
December 10, 2010, 11:28 |
Abhishek
Rep Power: 15 |
hi,
I just started using OpenFoam 1.5 with MS Windows. I followed the instructions to simulate the Lid Driven Cavity problem in the user guide which is available on OpenFoam site. But when I open Paraview, the "cavity.foam" does not appear in the builtin tree....I also tried to open it manually..but i didn't find any "cavity.foam" file in the directory. |
December 11, 2010, 02:28 |
Alberto Passalacqua
Rep Power: 36 |
The file is created by paraFoam, and it is an empty text file called as the case and with extension .foam or .OpenFOAM.
You can either use paraFoam directly, if it works on Windows, or create the file manually.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 11, 2010, 08:16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Just to complement Alberto's answer, this question has already been asked before and answered here: http://www.cfd-online.com/Forums/ope...tml#post234091, starting post #9 Best regards, Bruno
December 11, 2010, 10:30 |
Abhishek
Rep Power: 15 |
Thank you very much Alberto and Bruno !!!
Display Modes | |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
