Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Warnings from Paraview 5.4.0
Like Tree2Likes
  • 1 Post By lin
  • 1 Post By CFDFoundation
Old   September 2, 2017, 12:18
Default Warnings from Paraview 5.4.0
Markus Schmid
MSchmid is on a distinguished road
Hello together,
I have installed OpenFOAM 5.0 and ParaView 5.4.0 on Ubuntu 16.04 LTS.
Now I get the following warnings from ParaView:
Generic Warning: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.4.0/VTK/Rendering/Volume/vtkVolumeTextureMapper3D.cxx, line 680
vtkVolumeTextureMapper3D::vtkVolumeTextureMapper3D was deprecated for VTK 7.0 and will be removed in a future version.
Generic Warning: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.4.0/VTK/Rendering/VolumeOpenGL/vtkOpenGLVolumeTextureMapper3D.cxx, line 57
vtkOpenGLVolumeTextureMapper3D::vtkOpenGLVolumeTex tureMapper3D was deprecated for VTK 7.0 and will be removed in a future version.
How can I omit or supress those warnings?
Best regards,
Markus
MSchmid is offline   Reply With Quote
Old   September 19, 2017, 15:51
Alejandro
ancolli is on a distinguished road
I have the same problem. did u solve it?
ancolli is offline   Reply With Quote
Old   September 25, 2017, 14:06
Markus Schmid
Unfortunately not, I went back to OpenFOAM 4.1.
Old   September 25, 2017, 23:15
lin
Hua Zen
lin is on a distinguished road
I think you could just skip these warnings and continue to use OF50 as they are not errors
Akshay Soo likes this.
lin is offline   Reply With Quote
Old   October 14, 2017, 04:44
patricks is on a distinguished road
I have the very same problem ... Did somebody solve it?
patricks is offline   Reply With Quote
Old   October 31, 2017, 08:12
giorgos
giorgos is on a distinguished road
Same problem here. Did somebody manage to solve it?
Thanks
giorgos is offline   Reply With Quote
Old   November 1, 2017, 17:32
Retired Super Moderator
Bruno Santos
Quick answer: Those are just warnings. They are indicating that the legacy mode will be discontinued in the next major version of VTK.
Please report this on the issue tracker: https://bugs.openfoam.org/ - and please give the indication that the workaround to suppress this warning has to be done during compilation, as indicated here: http://the-unofficial-paraview-devel...ms-td5422.html
Old   November 12, 2017, 10:10
Default Problem opening .stl file with paraview5.4 used in openfoam5
Vu
DoQuocVu is on a distinguished road
Hi foamers,
I've just installed openfoam 5.0. When I test with cavity tutorial, the pop up window of paraview show this warning:
vtkOpenGLVolumeTextureMapper3D::vtkOpenGLVolumeTextureMapper3D was deprecated for VTK 7.0 and will be removed in a future version.
I think this warning is ok but when I try to open a .stl file that i made, paraview show this error:
ERROR: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.4.0/VTK/IO/Geometry/vtkSTLReader.cxx, line 472
vtkSTLReader (0x19e7780): STLReader: error while reading file /home/vu/OpenFOAM/vu-5.0/run/tutorials/cfdGroup/DTC-scaled.stl at line 3: unable to read STL vertex.
ERROR: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.4.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784
vtkPVCompositeDataPipeline (0x3a1a140): Algorithm vtkFileSeriesReader(0x3a19c70) returned failure for request: vtkInformation (0x1364d40)
  Debug: Off
  Modified Time: 186173
  Reference Count: 1
  Registered Events: (none)
  Request: REQUEST_DATA
  ALGORITHM_AFTER_FORWARD: 1
  FROM_OUTPUT_PORT: 0
  FORWARD_DIRECTION: 0
I then opened the DTC-scale.stl file from openfoam geometry resources folder and still get this error.
I have searched for solution but just found solution for Paraview4.4.0.
So do you have any idea about what can I do to fix this? or the only way is to install another OF version?
DoQuocVu is offline   Reply With Quote
Old   November 16, 2017, 04:12
ANKUR GARG
ankur_garg is on a distinguished road
I am not sure, but maybe once you could check your boundary conditions in the "0" folder, make sure you have provided the inputs for each patch in the proper order as they have designed in the source code. If there is a mismatch , you will get these kinds of warnings and other types as well.
Thank you very much.
Regards,
Ankur
Ankur Garg
ankur_garg is offline   Reply With Quote
Old   December 4, 2017, 07:17
Bruno Santos
Bug report has been made, along with patch instructions: https://bugs.openfoam.org/view.php?id=2779
And as expected, it's necessary to rebuild ParaView with the aforementioned option. Hopefully the Deb packages will be rebuilt as soon as possible.
Old   December 4, 2017, 15:32
Default Fixed issue with VTK warnings in ParaView
  #11
CFDFoundation is on a distinguished road
This issue has been resolved:
New packs for Ubuntu have been created. Details about upgrading are available here:
https://openfoam.org/news/v5-0-paraview-patch
Please note for future:
The place to report issues for OpenFOAM is https://bugs.openfoam.org. It is a dedicated bug tracking site, using bug tracking software, run by the people who fix issues with OpenFOAM.
The cfd-online.com site is not a dedicated bug tracking site, the forums are not running using bug tracking software, and the people who run them are not involved with OpenFOAM. So there is no point reporting the issues here.
wyldckat likes this.
CFDFoundation is offline   Reply With Quote
Old   February 7, 2021, 16:04
Evren Yilmaz Yakin
evrenykn is on a distinguished road
I take the same error.
My OpenFOAM version is v2012 and when I entered paraview, it's opening with that error.
How can I change the paraview automatic opening version? Paraview 5.4.1 but the lastest version is 5.9. I want to use it.
evrenykn is offline   Reply With Quote
paraview 5.4.0
[OpenFOAM] ParaView 5.4.0 refuses to start SamuelPei ParaView 1 October 15, 2019 03:12
[OpenFOAM.org] Building ParaView 5.4.0 with OpenFOAM 4.1 dferrando OpenFOAM Installation 4 June 21, 2019 10:01
[OpenFOAM.org] Paraview 5.4.0 compilation failed on centos 6.9 Saclay91 OpenFOAM Installation 1 March 24, 2018 20:20
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
