-   OpenFOAM Paraview & paraFoam (http://www.cfd-online.com/Forums/openfoam-paraview/)
-   -   Render result on geometry in ParaView. (http://www.cfd-online.com/Forums/openfoam-paraview/84666-render-result-geometry-paraview.html)
Bylund February 5, 2011 09:00
This is my first post here at cfd-online, I hope I do it correctly. ;)
I tried just for fun to make a primitive wind tunnel case which is basically just a cylinder with an extracted geometry (Sphere).
I can import the Sphere geometry from STL in ParaView. But how do I render the result (p for example) on the STL?
Example from Ansys:
http://airframeindia.org/images/CFD-...SauberF1-2.jpg
(I tried to search with no results, here nor google)
Thank you,
Christian
Bylund February 12, 2011 08:12
1 Attachment(s)
I have seemed to somewhat solved my problem.
This is how I did:
  • I created a geometry group in Salome for the evaluated geometry.
  • In paraview I select only this geometry in 'Mesh Region'.
  • I can also load more then one instance of the foam case to combine with a nice stream tracer.
Maybe someone else could benefit from this.
