[General] How Can I draw zero level set of a function with paraview |
August 2, 2017, 19:15 |
Ali
I have wrote an script in matlab (you can find it in below) that I need to know how can I export that to the paraview for drawing its zero level set. (based on my knowledge it would be a sphere).
clear clc N=4; k=[0:N/2-1 0 -N/2+1:-1]; l=[0:N/2-1 0 -N/2+1:-1]; m=[0:N/2-1 0 -N/2+1:-1]; t=0; dt=.01; T=200; eps=.01; % epsilon in the equation; Meps=1/eps; Mv=100; Ma=100; r0=1; phi0=zeros(N,N,N); tic; for i=1:N for j=1:N for n=1:N i j n fun1 = @(x,y,z) [cos(pi*(k(i)*x+l(j)*y+m(n)*z))-1i*sin(pi*(k(i)*x+l(j)*y+m(n)*z))].*tanh((r0-sqrt(x.^2 +y.^2 +z.^2 ))/eps); phi0(i,j,n)=integral3(fun1,-1,1,-1,1,-1,1); end end end toc; |
level set function, matlab, paraview |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
Coupling level set with volume of fluid. | Saideep | Main CFD Forum | 2 | July 1, 2016 20:43 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
