Home > Forums > OpenFOAM Paraview & paraFoam
velocity field for alpha 0 to 0.5 only
Old   June 11, 2011, 20:14
Default velocity field for alpha 0 to 0.5 only
Joel
Xhoven is on a distinguished road
If I have a free surface model, how could I make a velocity field that is only for the fluid and not for air? I see that I can create a contour and contour by an alpha value of 0.5 which will give me the interface of the fluid and air, but could I make a velocity profile for alpha = 0 to 0.5?
Xhoven is offline   Reply With Quote
Old   June 22, 2011, 05:41
DITO is on a distinguished road
Hi Xhoven
I don't know whether this is what you want, but what you could do, is to create an Isovolume of alpha from 0 to 0.5 and cut this via a slice.
the new slice you can color with the velocity.
Cheers,
DITO
DITO is offline   Reply With Quote
Old   June 22, 2011, 06:33
akidess's Avatar
Anton Kidess
I'm assuming you want to do this in paraview? Use the threshold filter with alpha 0.5, and then the glyph filter on the resulting data set.
Thread Tools
Trackbacks are On
Saving velocity field and reading it back for another case pranab_jha FLUENT 1 June 13, 2011 09:42
accessing another velocity field in bc daviderzen OpenFOAM 0 April 20, 2011 06:24
Reconstruction of velocity and pressure field Jianglan Main CFD Forum 0 October 6, 2008 00:04
velocity field Faiz Ahmed Main CFD Forum 0 March 5, 2006 11:11
transient temperature field with constant velocity Törnquist CFX 0 September 16, 2003 04:22
