[Sponsors] | |||||
Walter Schostak
Rep Power: 4 ![]() |
Hello Foamers!
I am happy to say that the work I've been doing is starting to get to the point where I need to make my post-processing visualizations look nice. I need to show the size of prominences that occur in this fluid and I would like to be able to put a ruler on the sides of the solution set to allow people looking at my work to see just how big they are. I've been searching through the paraView help and searching through the forums but I can't seem to find how to do it. I've attached my file, as you can see I've got a bunch of cool jets coming up, if you're curious it's a plasma/metal melt with viscosity taken into effect. I want to add a ruler to the left side and to the bottom (the space you're looking at is 0.2 cm by 0.2 cm) Thanks! |
Daniel
Rep Power: 5 ![]() |
One way is to go to the Display tab of the primary dataset and go to the Annotation section. There you can turn on the display of the boundaries and also edit them. I'm not sure if they will give you publication quality output though.
Hope this helps. Daniel |
| Tags |
| dimensions, paraview |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Paraview nice animation | PyGloo | ParaView | 4 | June 7, 2012 12:34 |
| Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
| Paraview not found | fusij | OpenFOAM Installation | 2 | January 1, 2011 20:44 |
| paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
| Paraview installation troubles | jjhall | OpenFOAM Installation | 3 | April 17, 2008 12:59 |
