[OpenFOAM] Showing dimensions in paraView
Old   July 20, 2011, 15:04
Default Showing dimensions in paraView
Walter Schostak
wschosta is on a distinguished road
Hello Foamers!
I am happy to say that the work I've been doing is starting to get to the point where I need to make my post-processing visualizations look nice. I need to show the size of prominences that occur in this fluid and I would like to be able to put a ruler on the sides of the solution set to allow people looking at my work to see just how big they are. I've been searching through the paraView help and searching through the forums but I can't seem to find how to do it.
I've attached my file, as you can see I've got a bunch of cool jets coming up, if you're curious it's a plasma/metal melt with viscosity taken into effect. I want to add a ruler to the left side and to the bottom (the space you're looking at is 0.2 cm by 0.2 cm)
Thanks!
wschosta is offline   Reply With Quote
Old   September 12, 2011, 10:36
Daniel
drrbradford is on a distinguished road
One way is to go to the Display tab of the primary dataset and go to the Annotation section. There you can turn on the display of the boundaries and also edit them. I'm not sure if they will give you publication quality output though.
Hope this helps.
Daniel
drrbradford is offline   Reply With Quote
dimensions, paraview
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) dslbkxd OpenFOAM Installation 1 February 3, 2018 00:56
Error: Comparing the result of DTCHullWaves with two different ParaView version ali.ikhsanul OpenFOAM 0 December 11, 2017 05:17
[General] Paraview is not showing any grid HectorRedal ParaView 0 October 30, 2017 17:08
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
[OpenFOAM] Distributed ParaView and PV3FoamReader micalil ParaView 4 July 1, 2010 05:09
