[OpenFOAM] Running paraFoam as a parallel job |
September 13, 2011, 05:09 |
#1 | ||
Hisham Elsafti
Rep Power: 17 |
Dear Foamers,
Does paraFoam runs as a parallel process by default or do I have to make an mpirun command. I ask that because as I've read about setting up a ParaView server, the client command was: Quote:
Feedback is welcome Best regards, Hisham |
September 13, 2011, 08:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Hisham,
Well, AFAIK, currently we cannot execute paraFoam itself in parallel. And I haven't been able to confirm this myself, but what we do need to do is:
A very important detail is that ParaView must be built with MPI capabilities for things to work properly, at least in the server machine. Usually this can be achieved with running in the ThirdParty folder: Code:
./makeParaView -mpi For more information on building ParaView, you can read here: Building ParaView 3.10.1 with custom Qt 4.6.4 Best regards, Bruno
running mapFields in parallel | mkhm | OpenFOAM Pre-Processing | 10 | September 16, 2021 13:12 |
[snappyHexMesh] Problem with boundaries with sHM in parallel running | Loekatoni | OpenFOAM Meshing & Mesh Conversion | 0 | January 24, 2019 07:56 |
How to use parallel running to the most? | 6863523 | OpenFOAM Running, Solving & CFD | 5 | January 19, 2017 02:22 |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 13:13 |
problem about running parallel on cluster | killsecond | OpenFOAM Running, Solving & CFD | 3 | July 23, 2014 21:13 |
