Home > Forums > OpenFOAM Paraview & paraFoam
How to load all <case>/surfaces/*/*.vtk at once into Paraview
Old   August 30, 2011, 04:40
Default How to load all <case>/surfaces/*/*.vtk at once into Paraview
Stefan
holodeck10 is on a distinguished road
Dear Foamers,
I am still new to OpenFoam and did not discover full functionallities. So I hope the question is easy for you guys.
I am looking for a fast way to extract slices from interFoam results (total size: ~20-50GB) and calculate fluxes for these areas over time.
The slices are located vertically somwhere inside the domain. Their extend is smaller than the whole lengths or widths of the domain. Cells have various sizes (I used blockMesh with simpleGrading).
- A slow way would be using foamToVTK, loading the results into Paraview, cutting off all parts of the domain which are beside the length of the desired slice, apply the slice filter, use the mesh quality filter to caluclate areas, calculate area*u-component*alpha1, export it to csv and then plot/analyze it using whatever.
- I would still let Paraview do the area/flux calculation, because I don't know an alternative.
- I meanwhile discovered some openFoam tools such as "cellSet", "cellsToZones" and "sample", but I got stucked, when I want to load the aforementioned "slices" which are now surfaces. I have all data, which I want to load into paraview in vtk files, but they are lying in seperate files for each time step and I have no idea how to load them all at once. I also tried various formats using "sample", including foamFile, but don't succeeded.
After that I have 3 questions:
1) Is there a better way to get my fluxes at these slices/surfaces?
2) If not, how can I load all vtk files of the surfaces directory into Paraview?
3) Is there a way to extract directly cell sizes from interFoam results, which can be used for flux calculation?
Thanks for any suggestion!
Best regards
Stefan
holodeck10 is offline   Reply With Quote
Old   September 9, 2011, 02:11
Bernhard
Bernhard is on a distinguished road
I don't know if it answers all your questions or not, but I sample the desired slices during runtime with the sampling library. Inside the functions( ); you can put something like this:
    sliceCentre
        type            surfaces;
        functionObjectLibs
            "libsampling.so"
        outputControl  outputTime;
        outputInterval  1;
        surfaceFormat  vtk;
        fields
            U
            alpha1
        surfaces
            sliceCentre
                type            plane;
                basePoint       (0.0 0.0 0.0);
                normalVector    (0.0 0.0 1.0);
                interpolate     true;
            //    regularise      false;
        interpolationScheme cell;
If you run paraview (in batch mode), you can easily loop over all this output with a python script.
Bernhard is offline   Reply With Quote
Old   September 9, 2011, 03:51
Stefan
Dear Bernhard,
thanks for your reply. It definitely rises my possibilities to treat this problem. So far, I arrived at the following stage:
- changed the source code in interFoam.C and createFields.H, so that it writes also cellsize. This prevents me from using Paraview, which is a bit slow for my purposes.
- used cellSet, setsToZone and sample in a shell script
That works quite well and I will probably change the source code further so that it calculates fluxes directly.
For all upcoming simulations I would have to extend your functions() section with cellSet and setsToZone. Do you know what is faster, doing cellSet, setsToZone and sample while simulation runs or during post-processing?
Cheers
Stefan
Old   September 9, 2011, 04:01
Bernhard
For your last question, I don't know which method is faster and whether it is a significant part compared to the total simulation time. However, if you sample during runtime, it may be sufficient to write less data, which also can be an advantage.
Old   September 9, 2011, 04:40
Stefan
True. Thank you for the comment!
Have a good day!
Stefan
Old   June 3, 2015, 05:30
SM
canopus is on a distinguished road
How can I load all vtk files of the surfaces directory into Paraview?
canopus is offline   Reply With Quote
Old   August 22, 2015, 13:00
Default Script to make VTK series readable in Paraview
Ken
Nucleophobe is on a distinguished road
Canopus,
Paraview can read a sequence of VTK files, but the VTK filenames must end in an incrementing integer value (e.g., 1,2,3... or 1000,1001,1002...).
See:
http://www.paraview.org/Wiki/Animati...TK_file_series
I use a bash script to rename the VTK files. You'll need to tailor this to your application, but something like:
#!/bin/bash
count=0
for i in $(ls surfaces); do
    echo "Folder name:" $i
    echo "VTK number:" $count
    cp surfaces/$i/U_interpolatedPlane.vtk VTK_for_Paraview/U_$count.vtk
    let "count++"
done
Hope that helps.
-Nuc
Nucleophobe is offline   Reply With Quote
Old   September 15, 2015, 07:18
Mikko
Flowkersma is on a distinguished road
You can also load the files with Python. First open one of your surface files with Paraview then open the Python Shell inside Paraview and write
import os
directory = '/path/to/directory/'
reader = GetActiveSource()
files = [directory + file for file in os.listdir(directory)]
# sort here the files if the order is important
files = sorted(files)
reader.FileNames = files
Now try changing the timestep.
-Mikko
Flowkersma is offline   Reply With Quote
Thread Tools
Trackbacks are On
Paraview doesn't seem to be picking up data generated by icofoam MikeHersee OpenFOAM Paraview & paraFoam 2 January 6, 2015 09:27
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Error Message while trying to load ParaView Online Help akku ParaView 2 March 6, 2013 01:47
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
ParaView Crashes During OF-case Load brosemu OpenFOAM Paraview & paraFoam 0 April 7, 2009 12:21
